Inventor Forum
Inventor 2014 Quick Access Toolbar Resets
13 REPLIES 13
Message 1 of 14
junibird
2085 Views, 13 Replies
I'm working with Inventor 2014, service pack 1, update 2.  I also have Vault 2014, update 2 installed.  I like to add coommands (like iProperties and Measure) to the quick access toolbar in Inventor.  The problem is that when I close Inventor and start it back up the added commands are gone from the quick access toolbar.  The worst part of it is that I have to add those commands back in the part, assembly, weldment and drawing environments.  Does anyone know if there's a fix for this issue?  Any help would be greatly appreciated.
13 REPLIES 13
Message 2 of 14
mdavis22569
in reply to: junibird
There is an update 3 now ..but that's not going to fix this problem. Unfortunately, I don't have a fix for the quick bar resetting.
Mike Davis
Message 3 of 14
guido_66
in reply to: mdavis22569
Many people (including me) have had this problem since Inventor 2010. I hope that it will be fixed in the 2015 release...
http://forums.autodesk.com/t5/Inventor-General/Quick-Access-Toolbar-looses-customization/m-p/3288309...
Message 4 of 14
junibird
in reply to: guido_66
This is the first release that I've had this problem.
Message 5 of 14
blair
Check if you don't have a "old" version of Inventor running in the background that didn't close properly. Inventor "writes" all changes to the program and settings upon proper closure of the program. If there is an "open" version still running, the changes won't be written. You can check this from the "Task Manager" or just re-boot the machine.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 6 of 14
blair
in reply to: blair
I might even try logging in as a different user after the re-boot. Possibly you could have an issue with your user profile.
Delta Tau Chi ΔΤΧ
Message 7 of 14
junibird
in reply to: blair
If by "old" you mean version 2013, the answer is no.  I remove all old versions of the software when loading new versions.  I did open task manager and closed Inventor.  There are no other instances of Autodesk software running when I close Inventor.  I'm running on a desktop and a laptop and have the same problem on both.  I have other co-workers who are having the same problem also.
Message 8 of 14
blair
No, same version, just never closed properly and is running in the background. Possibly look at your user profiles. You might not have sufficient privileges to write the updates from Inventor to the Windows Registry. You need at least Power User level (no replaced with Administrator. You might need your IT department to give you Local Admin access for your machines.
Delta Tau Chi ΔΤΧ
Message 9 of 14
junibird
in reply to: blair
Not that either.  I'm listed under the administrators group for both computers.
Message 10 of 14
blair
Any 3rd party add-ins? If so try disabling them.
Delta Tau Chi ΔΤΧ
Message 11 of 14
junibird
in reply to: blair
Here's screen pic of all of my add-ins.  I don't see any 3rd party and I've even shown the hidden add-ins.
Message 12 of 14
bob_holland
Mark,
I am posting this so that others will have access to this answer.
Please check to make sure that the folder and all sub folders are not read only:
C:\Users\USERID\AppData\Roaming
USERID = Users login ID
Bob Holland
Autodesk Product Support
Message 13 of 14
Bob's suggestion worked for me. Many thanks.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 14 of 14
amirx79
in reply to: bob_holland
this didn't help me at all because I couldn't change those folders from read only. So, is there any other way to solve this annoying problem? I run Inventor 2015 SP1.
