Inventor General
Active Contributor
Message 11 of 29 (633 Views)
Re: Inventor 2014 Pro stupidly slow all of a sudden
11-04-2013 12:56 PM in reply to: ccoomes
I have been trying to figure out a pattern to this issue but to not avail.
I've disable my Norton anti-virus which help for about 15 minutes. Then the lags came back.
My project file is fine.
The only odd thing I can point out is watching my task Manager under performance tab my CPU's are acting funny. I did have a couple of early morning meassages that the CPU what running hard.
When Inventor lags, only 1 (sometimes 2) of my 12 CPU's is maxed out while the others are sitting idle. I have no other applications or services adding to this.
Any thoughts?
*Expert Elite*
blair
Message 12 of 29 (627 Views)
11-04-2013 01:02 PM in reply to: edonline69
Are the files stored on the local machine or on a server. If it's on the server, try copying files to the local machine and test run it locally.
Try a system re-boot, look for other applications hogging memory. On the reboot it wouldn't hurt to open the case and see if your machine needs to be "blown-out" If a CPU is overheating it will throttle-back to reduce heat. Also check that all the memory boards are properly seated along with the graphics card and it's connections.
You should also be able to put exlusions in your Anti-Virus to ignore Inventor files: *.ipt, *.iam, *.idw and *.ipn.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Message 13 of 29 (576 Views)
11-19-2013 01:27 PM in reply to: blair
Everything suggested so far has been tried after I read or had been tried before. None if it fixes my issue.
It's just taken me 15 minutes to insert 1 bolt.
*Expert Elite*
blair
Message 14 of 29 (569 Views)
11-19-2013 01:37 PM in reply to: icouture
Check that you don't have a sick constraint, IV2014 now has a show sick constraints: Assembly Tab>Relationships>Show Sick Relationships. Also look for a bad sketch on a part in an assembly that might be referencing a part in another assembly that in this case is not used in this assembly.
Win7-64
Message 15 of 29 (549 Views)
11-20-2013 09:02 AM in reply to: blair
I fix any and all sick constraints as they happen, I never leave them there. That's not the problem either. Thanks still.
Distinguished Contributor
Message 16 of 29 (537 Views)
11-20-2013 10:50 AM in reply to: icouture
Have you tried anything like Process Explorer?  It might give some insight as to what is taking all the cycles.
KState92
Inventor Professional 2014 64 SP1 Update 3
Windows 7 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
*Expert Elite*
blair
Message 17 of 29 (531 Views)
11-20-2013 11:27 AM in reply to: kstate92
You might consider using the Microsoft Processor Affinity utility to assign certain application to other processors allowing Inventor to have processors all to it'self. http://www.techrepublic.com/blog/windows-and-office/change-the-processor-affinity-setting-in-windows...
Win7-64
Message 18 of 29 (478 Views)
12-04-2013 05:51 AM in reply to: edonline69
Tried everything suggested thus far, nothing works. I'm even on a fresh install, it keeps locking up out of the blue. One day it'll be fine all day, and the next I have to kill the process every 5 minutes because it's preventing me from doing any work.
This is getting quite aggravating.
Valued Mentor
Message 19 of 29 (465 Views)
12-04-2013 08:18 AM in reply to: icouture
Are you using any 3D connexion device?
Message 20 of 29 (463 Views)
12-04-2013 08:27 AM in reply to: Lancasterm
No I am not. I truly wish it was that simple, thank you still.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
