Inventor Forum
Inventor 2014 Mold base library empty
3 REPLIES 3
MiguelMayen
1527 Views, 3 Replies
I've been givin' my first steps in mold Design in my PDS 2014, specificly talkin' in Inventor Pro 2014.
The matter is that at the point of Mold base insertion, library seems to be empty, therefore I can't continue with my "interactive" mold designin'... Please help, it's an educational issue and it's almost urgent.
Thank you all
3 REPLIES 3
JDMather
in reply to: MiguelMayen
Edit your Project *.ipj
Click on the Configure Content Center Libraries icon in lower right corner of the Projects dialog box.
Is there a checkmark next to the desired Mold library?
If yes, then browse to the path indicated above and post screen shot of what is there.
There are two other mold libraries avialable as a separate download.
ampster401
if what JD points out doesn't work, the following link might help in getting it installed and setup;
http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/mold-design...
Just discovered that link this morning while I was searching for something else.
HTH
ampster401
in reply to: ampster401
ugh, I missed JD's last line of text - almost looks like that text is part of the screenshot.
The link I provided contains download links to the two missing mold libraries JD mentioned.
