Inventor General
Active Member
across
Message 71 of 112 (1,976 Views)
Re: Inventor 2014 Error 0xC0000142 on Windows 8
11-26-2013 11:27 AM in reply to: jessica.t
Jessica,
Sorry, I should mention that I am "across2211" above.  One account I use at work, the other at home.
All service packs / updates are installed.  I did the command prompt procedure, and can't get past the loading screen of Inventor.  After it disappears, so too does the process in task manager.
Employee
ChrisMitchell01
Message 72 of 112 (1,966 Views)
11-26-2013 12:36 PM in reply to: across
Can you check that you have full access rights to the %temp% folder ? Someone else had issues on win8.1 where they didn't have all the necessary rights there.
Remove all explicit permissions on %USERPROFILE%\AppData\Local\Temp and set to inherit permissions.
Or, go to Local Policies > Security Options, scroll to the bottom and set 'User Account Control: Run all administrators in Admin Approval Mode' to Disabled, then reboot.
Otherwise my only other suggestion is to uninstall/reinstall.
Chris
Chris Mitchell
Inventor Customer Engagement Team
Active Member
across2211
Message 73 of 112 (1,689 Views)
12-03-2013 05:17 PM in reply to: ChrisMitchell01
I just uninstalled/reinstalled.  Same problem!  I can't believe this is still happening.  Have you come across anyone else with this same problem?
New Member
fredrik.l.winje
Message 74 of 112 (1,654 Views)
12-04-2013 03:16 PM in reply to: across
I also have the same problem
blair
Message 75 of 112 (1,643 Views)
12-04-2013 07:57 PM in reply to: fredrik.l.winje
You could have a corrupt Profile. I will post a Windows Registry settings to repair the Windows Registry when I get back in the office next week.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
New Member
justin.parus
Message 76 of 112 (1,516 Views)
12-09-2013 07:56 PM in reply to: aslevins
I am also having this problem. Inventor Pro 2014 on windows 8.1
Edit: After installing SP1, Inventor seems to be working fine!
Active Member
across2211
Message 77 of 112 (1,445 Views)
12-11-2013 07:08 PM in reply to: blair
Blair, could you post these registry settings you mentioned?  I really don't know what else I can do at this point.  Thanks a lot!
blair
Message 78 of 112 (1,420 Views)
12-12-2013 09:09 AM in reply to: across2211
Here you go: The steps are as follows (Please substitute as appropriate for your version): 1. Exit Inventor 2. Open Regedit 3. Rename a. HKEY_CURRENT_USER\Software\Autodesk\Inventor\Current Version b. HKEY_CURRENT_USER\Software\Autodesk\Inventor\Current Version.org 4. Rename a. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion0.0 b. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion0.0.org 5. Rename a. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0 b. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0.org 6. Exit Regedit 7. Rename a. C:\Users\USERID\AppData\Local\Autodesk\Inventor 2014 b. C:\Users\USERID\AppData\Local\Autodesk\Inventor 2014.org 8. Rename a. C:\Users\hollanb\AppData\Roaming\Autodesk\Inventor 2014 b. C:\Users\hollanb\AppData\Roaming\Autodesk\Inventor 2014.org 9. Start Inventor and test. Note: RegistryVersion18.0 = Inventor Release 2014 RegistryVersion17.0 = Inventor Release 2013 RegistryVersion16.0 = Inventor Release 2012 RegistryVersion15.0 = Inventor Release 2011 RegistryVersion14.0 = Inventor Release 2010
Win7-64
Active Member
roblawarre
Message 79 of 112 (1,298 Views)
12-17-2013 08:33 AM in reply to: ChrisMitchell01
Will service pack 2 fix Inventor LT 2014 0xc0000142
New Member
Eqvaliser
Message 80 of 112 (1,257 Views)
12-18-2013 05:31 AM in reply to: blair
Dont have any of those folders you are descriping there under  %appadata%/autodesk/
at that location i have
Aotodesk sync
DWG Trueview
Web Services
But none labeled Inventor
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
