Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
Did you mean:Ā
Inventor 2014 Error 0xC0000142 on Windows 8
130 REPLIES 130
Message 1 of 131
aslevins
117574 Views, 130 Replies
I have uninstalled and reinstalled Inventor 2014 5 or 6 times and I am still recieving the error code 0xC0000142 upon start up.  I also have AutoCAD installed, which starts up fine.
Error Log:
<System>
  <Provider Name="Application Error" />
  <EventID Qualifiers="0">1000</EventID>
  <Level>2</Level>
  <Task>100</Task>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2013-08-06T04:17:38.000000000Z" />
  <EventRecordID>57992</EventRecordID>
  <Channel>Application</Channel>
  <Computer>Andrew-PC</Computer>
  <Security />
  </System>
<EventData>
  <Data>Inventor.exe</Data>
  <Data>18.0.17000.0</Data>
  <Data>512fe9d7</Data>
  <Data>KERNELBASE.dll</Data>
  <Data>6.3.9431.0</Data>
  <Data>51bd0a54</Data>
  <Data>e06d7363</Data>
  <Data>0000000000006aac</Data>
  <Data>217c</Data>
  <Data>01ce925be255dd0e</Data>
  <Data>D:\Files\Programs\Autodesk\Inventor 2014\Bin\Inventor.exe</Data>
  <Data>C:\WINDOWS\system32\KERNELBASE.dll</Data>
  <Data>20365b99-fe4f-11e2-befd-3085a9991555</Data>
  <Data />
  <Data />
  </EventData>
130 REPLIES 130
Message 61 of 131
After installing SP1 for Inventor Pro 2014 on my Windows 8.1 PC, Inventor still will not work.  I no longer get the "0xc000..." error, but the program is still not launching.  The initial loading screen appears, then quickly goes away, and Inventor never starts up after that.  Anyone else having this problem? VERY VERY frustrating.
Message 62 of 131
Did you try executing the command line prompt as referenced in the SP1 ReadMe ?
Additional Requirement to Re-register Inventor:
Perform the steps in the following solution link to re-register Inventor after SP1 is successfully installed.
Unable to Save As or Import DWG/DXF
Note that there is also Update1 fore SP1 available now.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22436654&linkID=9242019
Chris
Chris Mitchell
PDMS Customer Engagment Team
Message 63 of 131
Yes, I had done it previously (the update 1 to SP1 and also the command prompt procedure).  To be sure, I did both again.
Same problem.  I clicked my Inventor shortcut on the taskbar, the loading screen appears, disappears, and then nothing happens.  In my task manager, "Autodesk Inventor 2014" is listed as a background process, and then it also disappears when the loading screen goes away.  I really don't know what to do at this point. Smiley Frustrated
Message 64 of 131
across2211
in reply to: across2211
Anyone....anyone?
Message 65 of 131
tmatt746
in reply to: chucksavatsky
Now will this also be out for Inventor 2013. I use this one because it's what my school has and im hoping I won't have to download Inventor 14 just for it to work.
Message 66 of 131
ChrisMitchell01
in reply to: tmatt746
All fixes have been released. Please see the relevent support page for your version from:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?id=2334435&linkID=9242019&siteID=123112
If you read a few replies back you'll get the direct links & info.
Chris
Chris Mitchell
Message 67 of 131
What sort of h/w are you running ? If you have a laptop with onboard grpahics chip as well as a separate graphics card, try disabling one of them.
Do the log files in your %temp% folder reveal anything ?
Chris
Chris Mitchell
Message 68 of 131
Brand new (maybe 2 months old, tops) HP desktop PC:
Intel Core i7-4770 CPU @ 3.40 GHz
12 GB ram
Windows 8.1, 64-bit
NVIDIA GeForce GTX 645 display adapter
Message 69 of 131
across
in reply to: ChrisMitchell01
Any suggestions on this?  Would it help to do a complete re-install of Inventor?
Message 70 of 131
jessica.t
in reply to: across
Hi Andy,
What troubleshooting steps in the thread have you already taken to rectify the issue?
What kind of hardware are you working with?
Did you already install the necessary service packs?
If you could provide any additional nformation it would be greatly appreciated.
Thank you!
Jessica Thrasher
Message 71 of 131
across
in reply to: jessica.t
Jessica,
Sorry, I should mention that I am "across2211" above.  One account I use at work, the other at home.
All service packs / updates are installed.  I did the command prompt procedure, and can't get past the loading screen of Inventor.  After it disappears, so too does the process in task manager.
Message 72 of 131
ChrisMitchell01
in reply to: across
Can you check that you have full access rights to the %temp% folder ? Someone else had issues on win8.1 where they didn't have all the necessary rights there.
Remove all explicit permissions on %USERPROFILE%\AppData\Local\Temp and set to inherit permissions.
Or, go to Local Policies > Security Options, scroll to the bottom and set 'User Account Control: Run all administrators in Admin Approval Mode' to Disabled, then reboot.
Otherwise my only other suggestion is to uninstall/reinstall.
Chris
Chris Mitchell
Message 73 of 131
I just uninstalled/reinstalled.  Same problem!  I can't believe this is still happening.  Have you come across anyone else with this same problem?
Message 74 of 131
fredrik.l.winje
in reply to: across
I also have the same problem
Message 75 of 131
blair
in reply to: fredrik.l.winje
You could have a corrupt Profile. I will post a Windows Registry settings to repair the Windows Registry when I get back in the office next week.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi Ī”Ī¤Ī§
Message 76 of 131
justin.parus
in reply to: aslevins
I am also having this problem. Inventor Pro 2014 on windows 8.1
Edit: After installing SP1, Inventor seems to be working fine!
Message 77 of 131
across2211
in reply to: blair
Blair, could you post these registry settings you mentioned?  I really don't know what else I can do at this point.  Thanks a lot!
Message 78 of 131
blair
Here you go: The steps are as follows (Please substitute as appropriate for your version): 1. Exit Inventor 2. Open Regedit 3. Rename a. HKEY_CURRENT_USER\Software\Autodesk\Inventor\Current Version b. HKEY_CURRENT_USER\Software\Autodesk\Inventor\Current Version.org 4. Rename a. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion0.0 b. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion0.0.org 5. Rename a. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0 b. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0.org 6. Exit Regedit 7. Rename a. C:\Users\USERID\AppData\Local\Autodesk\Inventor 2014 b. C:\Users\USERID\AppData\Local\Autodesk\Inventor 2014.org 8. Rename a. C:\Users\hollanb\AppData\Roaming\Autodesk\Inventor 2014 b. C:\Users\hollanb\AppData\Roaming\Autodesk\Inventor 2014.org 9. Start Inventor and test. Note: RegistryVersion18.0 = Inventor Release 2014 RegistryVersion17.0 = Inventor Release 2013 RegistryVersion16.0 = Inventor Release 2012 RegistryVersion15.0 = Inventor Release 2011 RegistryVersion14.0 = Inventor Release 2010
Message 79 of 131
Will service pack 2 fix Inventor LT 2014 0xc0000142
Message 80 of 131
Eqvaliser
in reply to: blair
Dont have any of those folders you are descriping there under  %appadata%/autodesk/
at that location i have
Aotodesk sync
DWG Trueview
Web Services
But none labeled Inventor
