Inventor Forum
Inventor 2014 Editing Hatch Window off-screen on Dual Monitors
1 REPLY 1
JOLLYAL
609 Views, 1 Reply
Info:
OS: Windows 7 Pro
CPU: AMD FX-8350 @4.2ghz
GPU: Nvidia Quadro K4000
Monitors: Dual Asus 24" 1920x1080
Memory: 16gb
GPU Control Panel: Nvidia Version 331.65 for Quadro K4000
Autodesk Platform: Product Design Suite 2014
When I section a view and edit the hatches, the 'Edit Hatch Pattern' window always opens off-screen.  I have changed the settings in the GPU control panel to have everything open on the last window, but this window will not abide.  I move the window to the Inventor window (monitor 2), but it will re-open back to monitor 1 in the exact same position every time.  Has anyone else experienced this issue and is there a fix where this window will open within the Inventor window?  The 'Edit Hatch Pattern' window seems to be the only window that does this in Inventor.  Attached is a screencap of the issue.  The window opens in the same place each time.
OS: Windows 10 Pro
CPU: Intel i7-8700k @3.7ghz
GPU: Nvidia Quadro P4000
Memory: 32gb
GPU Control Panel: Nvidia Version 451.77 for Quadro P4000
Autodesk Platform: Product Design and Manufacturing Collection 2021
Tags (2)
1 REPLY 1
cwhetten
in reply to: JOLLYAL
I see the same behavior--no matter where I move the window, it always appears in the same spot.  But I use Inventor on my main monitor, so it isn't an inconvenience for me (and I never even noticed it before now).
I suspect that the developers either left out some functionality that allows the dialog to remember its previous postition, or they hard-coded it to always appear in the same spot.
I doubt there is anything you can do about it, although maybe one of the developers will see this post and offer some advice.
Cameron Whetten
IV2014 Pro SP1, Build 222; Vault Basic 2014 Update 1
Win 7 Pro 64-bit SP1; Intel Xeon Duo @2.40 GHz, 9 GB RAM,
NVIDIA Quadro 2000, 1024 MB GDDR5
