Hello, I just installed Inventor 2014 on my new PC and I discovered a weird issue. The default drawing sheet color is set on yellow, I know that I can change the color but how do I change the default color? Cause I don't want to change the color of the sheet to white every time I'm drawing something. I also have the software installed on my Notebook, but I don't have this problem there. Please help me, thank you.
Solved by admaiora. Go to Solution.
Hi Curt,
the sheet color of your image is the default native Inventor color sheet.
If you want to change it > Document Settings>Sheet> set your color
If you want it for all your drawing :
>Save As>Save Copy As Template
I hope that it can helps you,
Admaiora
You may have already realized this but even though the sheet appears to be a shade of yellow, it will print white. It is done this way so that working in the drawing is easier on the designer's eyes. However, if you want to change it, open the Template file through the open command and go to Tools / Document Settings / Sheet / Colors.
But it really is easier on the eyes to leave it at it's manilla default.
