I am having issues getting my .dwg files to check back in to Vault Basic. I can get all different types of files (.iam .ipt .idw) to check in without issues, but .dwg files hang and Inventor will eventually lock up.
I've tried disabling Visualization and I still cannot make it past this point. I can even tell it to check in everything at once, and it will breeze through the other files but any .dwgs will hang. Any help would be greatly appreciated.
My PC Config:
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
16 GB RAM
Dual AMD Radeon HD 6450
I'm running Product Design Suite 2014
Solved by sebgonz. Go to Solution.
Not being in IT and therefore not aware of all the settings, is there any setting in vault that control the types of files that are allowed in vault? Does 2014 have an add-on for Autocad Drawings? As I know even in 2011 I can not add Autocad Drawings without checking them into the vault through Autocad itself. Of course in 2011 it allows inventor drawings saved as dwg to be checked in, so not sure how this could affect it unless they forgot to add dwg acceptance?
You do have to check them in through Inventor, or else you get an error telling you that you have to use the correct program to perform that operation. I have not looked through the vault settings to see if there is anywhere that allows or disallows file types. I will do this next.
I can't believe no one from Autodesk has bothered to chime in yet!
Our dev team recently investigated this; on the vault server, please look for & then delete the temporary file:
C:\Windows\Temp\UNDDACAD.ac$
The retry the dwg check-in.
Hop ethis helps,
Chris
Deleted that Temp file, still having the same issues. My system as well as two others are still hanging when checking in to vault.
This is now beyond frustrating.
I'll ask for further info from the vault dev team & reply back.
As an additional test it wouldn't harm to try deleting all files in the %temp% folders on the clients too. Any files in use won't be removed.
-Chris
Yeah, I did that at the same time as deleting the temp file you referenced. I installed everything in the Design Suite, thinking that maybe I had unchecked something vital to the install when I set my preferences, but it didn't make a difference.
Alright. Here is the solution. Subscribe to this, in case you ever need it.
1. On all ADMS’, examine the content of the ‘C:\Windows\Temp’ directory for ‘UNDDACAD.ac$’.
2. Check the file date. If it is much older than the installation date (or if you want to test this), proceed…
3. Invoke IISRESET /STOP.
4. Move ‘UNDDACAD.ac$’ out of the ‘C:\Windows\Temp’ directory.
5. Invoke IISRESET /START.
6. Test DWG check in.
a. The check in will generate a current version of ‘UNDDACAD.ac$’ (you may want to verify the new date).
Chris mentioned this, but did not mention the part about stopping and restarting the IIS server. Thanks to everyone who tried to help me with this. I owe you all beer or donuts.
Thanks for posting this, I somehow just ran into the same trouble on my machine. Your solution worked like a charm.
I have several users having the same problem as described. Any dwg file either created from Autodesk Inventor 2014 or AutoCAD 2014... doesn't matter. The Vault will not check these files in.
Did you try the marked solution listed above?
Yes Client And server are both on the same Workstation Windows 8.1 64bit...??? I cannot find solution for this...
