Inventor General
Active Contributor
sebgonz
Message 31 of 54 (1,756 Views)
Re: Inventor 2014 DWG will not Check In to Vault
05-30-2013 02:40 PM in reply to: sebgonz
Alright. Here is the solution. Subscribe to this, in case you ever need it.
1.       On all ADMS’, examine the content of the ‘C:\Windows\Temp’ directory for ‘UNDDACAD.ac$’.
2.       Check the file date.  If it is much older than the installation date (or if you want to test this), proceed…
3.       Invoke IISRESET /STOP.
4.       Move ‘UNDDACAD.ac$’ out of the ‘C:\Windows\Temp’ directory.
5.       Invoke IISRESET /START.
6.       Test DWG check in.
a.       The check in will generate a current version of ‘UNDDACAD.ac$’ (you may want to verify the new date).
Chris mentioned this, but did not mention the part about stopping and restarting the IIS server.  Thanks to everyone who tried to help me with this. I owe you all beer or donuts.
My PC Config:
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
16 GB RAM
Dual AMD Radeon HD 6450
Running Product Design Suite 2014
Distinguished Mentor
swhite
Message 32 of 54 (1,738 Views)
05-30-2013 02:54 PM in reply to: sebgonz
Beer :smileyhappy:, but donuts good too :smileyhappy:
Glad you found a solution!
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Active Member
pcetnar
Message 33 of 54 (1,573 Views)
08-05-2013 06:32 PM in reply to: sebgonz
Thanks for posting this, I somehow just ran into the same trouble on my machine.  Your solution worked like a charm.
New Member
tobias.brogren
Message 34 of 54 (1,494 Views)
09-02-2013 06:34 AM in reply to: sebgonz
It works! Thanks!
Active Member
Oesh01
Message 35 of 54 (1,332 Views)
10-22-2013 09:02 AM in reply to: sebgonz
I have several users having the same problem as described.  Any dwg file either created from Autodesk Inventor 2014 or AutoCAD 2014... doesn't matter.  The Vault will not check these files in.
Active Contributor
sebgonz
Message 36 of 54 (1,288 Views)
10-30-2013 11:25 AM in reply to: Oesh01
Did you try the marked solution listed above?
My PC Config:
16 GB RAM
New Member
petropnik
Message 37 of 54 (1,223 Views)
11-16-2013 05:08 AM in reply to: sebgonz
I have the same problem.
I go to c:\windows\temp\ and I cannot find the file unddacad.ac$?
ANy ideas. I am stuck...
Windows 8.1
Active Member
Oesh01
Message 38 of 54 (1,200 Views)
11-19-2013 08:17 AM in reply to: petropnik
unddacad.ac$ is located on the ADMS.  Have you checked your Vault server?
New Member
petropnik
Message 39 of 54 (1,167 Views)
11-25-2013 07:51 AM in reply to: Oesh01
Yes Client And server are both on the same Workstation Windows 8.1 64bit...??? I cannot find solution for this...
Are_42
Message 40 of 54 (1,108 Views)
12-03-2013 04:06 AM in reply to: petropnik
Same problem here, Windows 8.1. No temp file, can't check in inventor dwg files.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
