Inventor General
Active Contributor
sebgonz
Message 1 of 50 (2,736 Views)
Accepted Solution
Inventor 2014 DWG will not Check In to Vault
2736 Views, 49 Replies
05-29-2013 07:23 AM
I am having issues getting my .dwg files to check back in to Vault Basic. I can get all different types of files (.iam .ipt .idw) to check in without issues, but .dwg files hang and Inventor will eventually lock up.
I've tried disabling Visualization and I still cannot make it past this point. I can even tell it to check in everything at once, and it will breeze through the other files but any .dwgs will hang. Any help would be greatly appreciated.
My PC Config:
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
16 GB RAM
Dual AMD Radeon HD 6450
I'm running Product Design Suite 2014
My PC Config:
16 GB RAM
Running Product Design Suite 2014
Distinguished Contributor
jddickson
Message 2 of 50 (2,715 Views)
Re: Inventor 2014 DWG will not Check In to Vault
05-29-2013 08:31 AM in reply to: sebgonz
Do you have any iLogic rules in your drawings? If you do try suppressing them before checking the drawings into vault. If it works after suppressing the rules then you can narrow it down to the code that is interfering with checking it in.
Not sure if this is the problem but I hope this helps.
Active Contributor
sebgonz
Message 3 of 50 (2,711 Views)
05-29-2013 08:43 AM in reply to: jddickson
Thanks for the reply. I don't have any iLogic in the drawings. Actually, I don't think I have any iLogic in any parts that I'm currently experiencing this with.
I did forget to mention that this is happening on 3 different systems. I'm not the only user here experiencing it.
My PC Config:
16 GB RAM
Message 4 of 50 (2,704 Views)
05-29-2013 08:52 AM in reply to: sebgonz
Spoiler
Is that .DWG file created directly from Inventor 3D assembly? Try creating from from .idw file
Active Contributor
sebgonz
Message 5 of 50 (2,702 Views)
05-29-2013 09:00 AM in reply to: kgadgil
I'm not sure I understand what you mean by "created directly from Inventor 3D assembly". We create the dwg separately and place our views into it.
My PC Config:
16 GB RAM
jddickson
Message 6 of 50 (2,694 Views)
05-29-2013 09:10 AM in reply to: sebgonz
I noticed that there is a Logo on your drawing. Do you know how that is inserted into the drawing? If it’s a linked picture in Vault it might cause some problems depending on how it’s checked out or checked in.
Active Contributor
sebgonz
Message 7 of 50 (2,691 Views)
05-29-2013 09:23 AM in reply to: jddickson
It is embedded. It has not caused any issues in previous releases.
I've also created this video showing exactly what I'm doing when I get the error. http://youtu.be/njbztuGn4TI
Additionally, after I manage to get out of the frozen screen, if I can without having to kill the process, I get this error:
"The server returned the following information: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server."
My PC Config:
16 GB RAM
Distinguished Mentor
Message 8 of 50 (2,687 Views)
05-29-2013 09:36 AM in reply to: sebgonz
I have had this issue before, it is frustrating as hell. You need to open your main assembly, go to the vault view on the browser instead of the model view. Expand every single subassembly until you find the part or parts that are red and check it out. It will most likely be a library file that was converted from a previous release that did not take properly. And I expect everytime you open this assembly and say yes to replace from vault, the same thing will occur unless you open that library file directly and save it with a library modification project path.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
jddickson
Message 9 of 50 (2,684 Views)
05-29-2013 09:41 AM in reply to: sebgonz
I don’t know if this will make any difference:
  1. In Vault go to options under the tools tab
  2. Check the show hidden files tab
  3. Find your file in Vault. There should be a .DWF file with the same name.
  4. Delete the .DWF file.
  5. Try to check out the DWG file and check it back in.
  6. Turn off the show hidden files tab
Hope this helps
Is this the only file you are having problems with?
it
New Member
it
Message 10 of 50 (2,673 Views)
05-29-2013 10:27 AM in reply to: jddickson
I just tried what you suggested. I showed hidden files, deleted the dwf, and tried checking in the dwg. That still hasn't fixed the problem. It happens with any dwg I try to check in. Even brand new dwgs created in Inventor 2014.
I'm starting to think that it may have something to do with the vault server installation. I have no theory as to why, but where it's happening with 3 different systems, it makes more sense to me.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
