Inventor Forum
Inventor 2014 Crashes while loading
13 REPLIES 13
Message 1 of 14
rkirk77
1957 Views, 13 Replies
I have been roaming the various forums and have tried the following.
I am using Windows 8.1
Un-install / Re-Install
Updated drivers (GeForce 580)
Updated to SP1
The program get about 3/4's loaded and the error report pops up..
Suggestions?
Windows 8.1 Pro 64-bit
Intel i7 870 @ 2.93 GHz
Nvidia GeForce 580 GTX 1536MB GDDR5
8 GB Ram
250GB HDD
13 REPLIES 13
Message 2 of 14
CCarreiras
in reply to: rkirk77
Hi!
Inventor 2014 (and others softwares, not only Autodesk) doesn't working in win 8.1.
Or wait a few time or downgrade your windows to "Windows 8".
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CCarreiras
Message 3 of 14
rkirk77
in reply to: CCarreiras
I also have 3ds max, Mudbox, and Soft Image.. and they all work..
8 GB Ram
250GB HDD
Message 4 of 14
rangt
Though not officially supported, 2014 should work on Win8.1 but you do need to have the 2014 Sp1 installed.  You mention that you do but could you double check that please?  I wouldn't be surprised to hear of a start up crash, like the one you describe, prior to you installing the SP1.  Could you also provide your machine specs?  Have you been submitting the Crash Reports?  If so, could you reply privately to me with the e-mail address you used so I could look at them and see if we can narrow down what the cause could be?
Tom Rang
Software Quality Assurance Manager
Autodesk, Inc.
Message 5 of 14
BeKirra
The other things may be to ensure your machine hardwares match the inventor 2014 system requirements.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 6 of 14
rkirk77
in reply to: BeKirra
My computer is an Intel i7 870, 8 gigs ram, Geforce 580 GTX.  The program was working last week.. and now nothing.
8 GB Ram
250GB HDD
Message 7 of 14
rkirk77
The issue still remains, and I have no real answers..  ANYONE?
8 GB Ram
250GB HDD
Message 8 of 14
rkirk77
Kinda feel like this --> http://youtu.be/ilcRS5eUpwk
8 GB Ram
250GB HDD
Message 9 of 14
rangt
I had a developer look at your crash report and the first thing he sees is an exception being thrown by Vault.  Are you using Vault?  What version? And have you installed any/all Vault Service Packs / Updates?
Tom Rang
Autodesk, Inc.
Message 10 of 14
rkirk77
in reply to: rangt
I have not been using / updating vault.
What is Vault? ROFL
8 GB Ram
250GB HDD
Message 11 of 14
rkirk77
I did an update to Vault 2014 Basic (which I apparently have..) and it did nothing.
8 GB Ram
250GB HDD
Message 12 of 14
rkirk77
Problem Solved!
Apparently Adobe Vault was giving Inventor some issues and prevented it from loading, so it was quite simple.. Uninstall Vault!
Thanks to rangt for the help!
Very much appreciated!!
8 GB Ram
250GB HDD
Message 13 of 14
sanjindr
in reply to: rangt
You saved my buts 😄 thank You a looootttt...I instaled stupid win 8.1 and I had problems with my main tool Inventor and after I installed sp1 everything work great thank You Your comment make my day 😄 thank Youu.
Sanjin
Message 14 of 14
Heathos88
Adobe Vault or Autodesk Vault?.
I think I have a similar problem:
Specs: Inventor 2014 on win 8.1. Hangs (sometimes) but doesn't crash when loading (checking out) from Vault.
Not sure what causes it.. have the same problem on two machines so it could be a server issue..
Once had a similar looking problem with a window popping up outside of the screen range (Alt+Space to move back again).
I have all the latest servies packs, updates and for both Vault and Inventor.
Any one have the same issue?
