Inventor Forum
Inventor 2013 sheet metal hem feature sucks
8 REPLIES 8
Message 1 of 9
oldfahrt
1089 Views, 8 Replies
I mentioned this issue long time ago (Inventor 2011) and somebody from Autodesk developing team responded, promising an fix in next version. Unfortunately nothing happen and the problem still exists: ability to hem all edges of - say - square piece of sheet metal with single command. This will result with properly notched mitered corners of flat piece. Solid Works does it, and I believe it's not a brainer do implement such logic approach in Inventor...
8 REPLIES 8
Message 2 of 9
BLHDrafting
in reply to: oldfahrt
You can use Contour Flange to do this. It's not perfect and probably not as easy as a proper HEM command would be but it's still do-able. Below are some links to blog articles I wrote on this. They might help. Good luck.
http://blh.com.au/#/blog/4572268941/Cool-Sheet-Metal-Contour-Flange-tip/4620401
http://blh.com.au/#/blog/4572268941/Sheetmetal-internal-corners-using-Contour-Flange/5798487
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
Message 3 of 9
Cadmanto
You can also place this in the Inventor IdeaStation.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 9
oldfahrt
in reply to: BLHDrafting
Of course the Contour Flange method will do the trick some 50 mouse clicks later, but that's not the point of my post...
Message 5 of 9
JDMather
Only takes me a handfull of  clicks - you must be doing something wrong.  Attach your file here.
Message 6 of 9
oldfahrt
in reply to: JDMather
JDMather, this is simple: create new standard sheet metal part file, sketch
an rectangle, face it and - finally - apply a *contour sketch of hem with
controllable features and parameters*. Good luck with just a "couple of
mouse clicks" !
Message 7 of 9
JDMather
You must have mis-understood my technique.
I am familiar with the SolidWorks technique, I am using the Inventor technique that works, not trying to force Inventor to work like SolidWorks.
Perhaps this is where you need to post your problem description
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
I understand your frustration.
Every day I run into the same thing - trying to get SolidWorks to do things that are so easy in Inventor....
Message 8 of 9
oldfahrt
OK, let's make sure we're on the same page:
1. I love Inventor and I'm not SW user.
2. I'm not trying to either compare or get any of these apps to do things
the same way.
3. I know for sure there's a workaround for multiple edge hemming in
Inventor, and I have no problem executing one of several methods already
discussed at this forum.
4. Said that, what is the purpose for HEM button on Inventor's sheet metal
Create tab, knowing it's obvious limitations? I can live with that, but
small improvements there will be welcomed, and that was the only reason for
my post.
cheers.
Message 9 of 9
mcgyvr
Yes Solidworks does some things better/easier than Inventor and Inventor does some things better/easier than Solidworks..
If you really like the way Solidworks or any other CAD package does something vs Inventor then the "ideastation" as posted above is where you should put that suggestion.
IF there is enough demand it might actually get implemented.. But don't hold your breathe.... Heck I do sheet metal parts all the time and have NEVER used the hem command once since Inventor R8..
