Inventor General
Active Member
Message 1 of 9 (382 Views)
Accepted Solution
Inventor 2013 sheet metal hem feature sucks
382 Views, 8 Replies
11-20-2013 01:57 PM
I mentioned this issue long time ago (Inventor 2011) and somebody from Autodesk developing team responded, promising an fix in next version. Unfortunately nothing happen and the problem still exists: ability to hem all edges of - say - square piece of sheet metal with single command. This will result with properly notched mitered corners of flat piece. Solid Works does it, and I believe it's not a brainer do implement such logic approach in Inventor...
Valued Mentor
BLHDrafting
Message 2 of 9 (377 Views)
Re: Inventor 2013 sheet metal hem feature sucks
11-20-2013 02:20 PM in reply to: oldfahrt
You can use Contour Flange to do this. It's not perfect and probably not as easy as a proper HEM command would be but it's still do-able. Below are some links to blog articles I wrote on this. They might help. Good luck.
http://blh.com.au/#/blog/4572268941/Cool-Sheet-Metal-Contour-Flange-tip/4620401
http://blh.com.au/#/blog/4572268941/Sheetmetal-internal-corners-using-Contour-Flange/5798487
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
*Expert Elite*
Cadmanto
Message 3 of 9 (354 Views)
11-20-2013 06:29 PM in reply to: oldfahrt
You can also place this in the Inventor IdeaStation.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Active Member
Message 4 of 9 (337 Views)
11-20-2013 11:38 PM in reply to: BLHDrafting
Of course the Contour Flange method will do the trick some 50 mouse clicks later, but that's not the point of my post...
*Expert Elite*
Message 5 of 9 (322 Views)
11-21-2013 02:22 AM in reply to: oldfahrt
Only takes me a handfull of  clicks - you must be doing something wrong.  Attach your file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Member
Message 6 of 9 (277 Views)
11-21-2013 11:06 AM in reply to: JDMather
JDMather, this is simple: create new standard sheet metal part file, sketch
an rectangle, face it and - finally - apply a *contour sketch of hem with
controllable features and parameters*. Good luck with just a "couple of
mouse clicks" !
*Expert Elite*
Message 7 of 9 (274 Views)
11-21-2013 11:13 AM in reply to: oldfahrt
You must have mis-understood my technique.
I am familiar with the SolidWorks technique, I am using the Inventor technique that works, not trying to force Inventor to work like SolidWorks.
Perhaps this is where you need to post your problem description
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
I understand your frustration.
Every day I run into the same thing - trying to get SolidWorks to do things that are so easy in Inventor....
Active Member
Message 8 of 9 (262 Views)
11-21-2013 12:38 PM in reply to: JDMather
OK, let's make sure we're on the same page:
1. I love Inventor and I'm not SW user.
2. I'm not trying to either compare or get any of these apps to do things
the same way.
3. I know for sure there's a workaround for multiple edge hemming in
Inventor, and I have no problem executing one of several methods already
discussed at this forum.
4. Said that, what is the purpose for HEM button on Inventor's sheet metal
Create tab, knowing it's obvious limitations? I can live with that, but
small improvements there will be welcomed, and that was the only reason for
my post.
cheers.
*Expert Elite*
mcgyvr
Message 9 of 9 (253 Views)
11-21-2013 01:15 PM in reply to: oldfahrt
Yes Solidworks does some things better/easier than Inventor and Inventor does some things better/easier than Solidworks..
If you really like the way Solidworks or any other CAD package does something vs Inventor then the "ideastation" as posted above is where you should put that suggestion.
IF there is enough demand it might actually get implemented.. But don't hold your breathe.... Heck I do sheet metal parts all the time and have NEVER used the hem command once since Inventor R8..
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2014 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
