Inventor General
weavty1
Message 11 of 23 (2,611 Views)
Re: Inventor 2013 really slow
11-16-2012 05:57 AM in reply to: jonathanruffray
PLEASE!
Because I just waited over a minute to change a content center bolt's length, for it to 'update part'.... Dang.
I can't be dealing with these hangups like this, guys... I have models to make, and products to push out!!
:smileysad:
Active Contributor
jonathanruffray
Message 12 of 23 (2,565 Views)
11-21-2012 04:50 AM in reply to: weavty1
Weavty1,
Did you migrate your content center files, your styles, colors, templates, etc...
Did you used Vault?
Is your content center on the network, on vault or in local on your machine?
We need to find what's wrong...
Autodesk Product Design Suite Ultimate 2013
Win 7 Pro 64 bits SP1
Bi-Xeon E5520 (2x Quad-core @2.27GHz)
Quadro Fx 1800 768Mo GDDR3
6Go Ram DDR3 667MHz ECC
LT.Rusty
Message 13 of 23 (2,556 Views)
11-21-2012 06:21 AM in reply to: jonathanruffray
I'm not Weavly, but I do have some of the same issues.  I don't think it's quite as slow as that, but it's still pretty slow.
I have a Vault, but I don't use it - my project is set up to be completely local and self-sufficient.  Everything is on the local machine.  Everything is migrated, except for Content Center which was a new installation for 2013.  (2011 used the network content center.)
___________________________________________________________
Product Design Suite Ultimate 2013, 2014, 2015
Work: Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Home: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / Radeon R9-270X 4GB
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
weavty1
Message 14 of 23 (2,545 Views)
11-21-2012 07:17 AM in reply to: jonathanruffray
Content Center files are all stored locally. All Styles are as well, etc.
I had not migrated anything from a legacy version, nor have I used Vault for anything yet. So I should not have any issues with that at the moment.
Everything is installed and ran locally on my workstation (PC) here at the office.
randym19ca
Message 15 of 23 (2,524 Views)
11-22-2012 11:42 AM in reply to: nuclair
Are you running an SSD or HDD?  If you are running a 5400 RPM HDD you will definitly experience slowdowns.
Randy
Intel Xeon W3565 3.2 GHZ
12 GB Ram
256 GB OCZ Vertex 3 SSD
ATI FirePro V5700
Active Contributor
jonathanruffray
Message 16 of 23 (2,506 Views)
11-23-2012 12:19 AM in reply to: randym19ca
I'm equipped with 7200RPM HDDs, but even if I was using 5400 Rpm HDD they shall be not have a so big difference between Inventor 2012 and Inventor 2013...
From what I see from this post, we all have a well configured computer (Up to 32Gb RAM in this thread) to run Inventor whithout been laggy....
And it happens that we use network or local files, Vault or not...
Attached a video of the new function slow down between  network (H:smileyhappy:  and local (D:smileyhappy: drive. See How it's slow with Inventor 2013... :smileysad:
Valued Contributor
petrxn
Message 17 of 23 (2,493 Views)
11-23-2012 01:36 AM in reply to: nuclair
My experrience is that if I change project I have to restart Inventor. If not the Inventor is very, very slow. Also missing file of material library (adsklib) slows Inventor. Could not be this your problem?
weavty1
Message 18 of 23 (2,429 Views)
11-30-2012 07:34 AM in reply to: nuclair
BUMP FOR HELP!! Please!! Ugh.... This is getting EXTREMELY annoying.
weavty1
Message 19 of 23 (2,394 Views)
12-05-2012 06:14 AM in reply to: weavty1
bump?
b.mccarthy
Message 20 of 23 (2,369 Views)
12-06-2012 04:54 PM in reply to: weavty1
I experienced the same performance issues after I installed PRDSU2013 (one small assembly of 40+ parts took 2 hours to open). The problem (for me, at least) stemmed from the custom material definitions I had created in 2012 and previous, which did not migrate successfully to the new release's Material and Appearance Libraries definitions. I also have alot of custom content in the Content Center, which affected the performance as well. My solution required purging all of the custom definitions and applying a new, similar one from within the new libraries. Unmodified definitions had to be updated. After many, many hours of purge/update, 2013 now runs @90% of the speed of 2012. Not great, but much better. I'm still trying to track down some pesky problems in some sheet metal parts.
If you create any custom materials/appearances, I would recommend following the steps outlined here:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1364-Fundamen1364/1443-Materia...
The process is a little different depending upon whether it is begun from within an idw or iam/ipt
When in a idw, follow these steps in order:
  1. Manage > Styles and Standards > Purge. The "Purge Styles" will open.
  2. Check "Purge Sub-Styles" and "Purge Styles from All Child Documents"
  3. Select "Yes to All" and Click Ok. If the "Update Locally Edited Styles?" dialog pops up, Click "Yes" as well. This can take awhile.
  4. Manage > Styles and Standards > Update. The "Update Styles" dialog will open.
  5. Check "Update Styles in All Child Documents"
  6. Select "Yes to All" and Click Ok. If the "Update Locally Edited Styles?"   dialog pops up, Click "Yes" as well. This, again, can take awhile
When in a iam or ipt, follow these steps in order:
  2. Check "Styles", "Materials",  "Purge Sub-Styles" and "Purge Styles from All Child Documents" If you completed the steps in the "Library Management Methods" above, you will see your new material library under the "Compare Materials against" area. You can select any of the existing libraries to compare with.
  3. Select "Yes to All" and Click Ok. If the "Update Locally Edited Styles?" dialog pops up, Click "Yes" as well. This may take awhile.
  5. Check "Styles", "Materials" and  "Update Styles in All Child Documents"
  6. Select "Yes to All" and Click Ok. If the "Update Locally Edited Styles?" dialog pops up, Click "Yes" as well. This, again, may take awhile.
This is an ongoing process, obviously, and I re-create my custom materials and appearances as needed, or when I have time, using the Asset Management project defined above. If any of my custom materials had been applied to custom items in the Content Center, then they have to be redefined, too.
This may or may not affect your issue, but perhaps it will help..
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
