Hi varindersra,
You can find an example at this link:
http://inventortrenches.blogspot.com/2012/05/ilogic-rule-to-change-units-of-measure.html
I hope this helps.
Curtis
Thanks for the reply. I tried the code in assembly environment but it gives me an "Unspecified Error". I am using the following code please correct. And also could you provide me the code (UnitsType Enumerators) for "ft" units.
DimopenDocAsDocument
openDoc=ThisDoc.Document
openDoc.unitsofmeasure.LengthUnits=oUOM_1
IfTest1="1"Then
oUOM_1=11269
ElseIfTest1="2"Then
oUOM_1=11272
EndIf
Please correct
Regard!
Varinder
Please use the iLogic rule to change the unit with the steps below -
1. Create one unitless user parameter named "Test1"=1
2. Please copy and paste the code lines below in iLogic rule
Dim openDoc As Document
If Test1=1 Then
oUOM_1=11269 'Millimeter Length
ElseIf Test1=2 Then
oUOM_1=11272 'inch length
ElseIf Test1=3 Then
oUOM_1=11273 'foot length
End If
3. When the change value of Test1, the unit in document will be changed.
For the other unit, please refer the attached spreadsheet.
