Inventor Forum
Inventor 2013 iLogic unit change
3 REPLIES 3
varindersra
2067 Views, 3 Replies
How do I chnage the document units using iLogic rules.
Regards!
varinder
3 REPLIES 3
Hi varindersra,
You can find an example at this link:
http://inventortrenches.blogspot.com/2012/05/ilogic-rule-to-change-units-of-measure.html
I hope this helps.
Curtis
Thanks for the reply. I tried the code in assembly environment but it gives me an "Unspecified Error". I am using the following code please correct. And also could you provide me the code (UnitsType Enumerators) for "ft" units.
DimopenDocAsDocument
openDoc=ThisDoc.Document
openDoc.unitsofmeasure.LengthUnits=oUOM_1
IfTest1="1"Then
oUOM_1=11269
ElseIfTest1="2"Then
oUOM_1=11272
EndIf
Please correct
Regard!
Varinder
Yijiang.Cai
in reply to: varindersra
Please use the iLogic rule to change the unit with the steps below -
1. Create one unitless user parameter named "Test1"=1
2. Please copy and paste the code lines below in iLogic rule
Dim openDoc As Document
If Test1=1 Then
 oUOM_1=11269 'Millimeter Length
ElseIf Test1=2 Then
 oUOM_1=11272 'inch length
ElseIf Test1=3 Then
 oUOM_1=11273 'foot length
End If
3. When the change value of Test1, the unit in document will be changed.
For the other unit, please refer the attached spreadsheet.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
