Inventor General
Distinguished Contributor
Message 1 of 4 (758 Views)
Inventor 2013 iLogic unit change
758 Views, 3 Replies
08-23-2012 11:26 AM
How do I chnage the document units using iLogic rules.
Regards!
varinder
Curtis_Waguespack
Message 2 of 4 (756 Views)
Re: Inventor 2013 iLogic unit change
08-23-2012 11:31 AM in reply to: varindersra
Hi varindersra,
You can find an example at this link:
http://inventortrenches.blogspot.com/2012/05/ilogic-rule-to-change-units-of-measure.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Message 3 of 4 (743 Views)
08-23-2012 02:43 PM in reply to: Curtis_Waguespack
Thanks for the reply. I tried the code in assembly environment but it gives me an "Unspecified Error". I am using the following code please correct. And also could you provide me the code (UnitsType Enumerators) for "ft" units.
DimopenDocAsDocument
openDoc=ThisDoc.Document
openDoc.unitsofmeasure.LengthUnits=oUOM_1
IfTest1="1"Then
oUOM_1=11269
ElseIfTest1="2"Then
oUOM_1=11272
EndIf
Please correct
Regard!
Varinder
Employee
Message 4 of 4 (735 Views)
08-23-2012 08:16 PM in reply to: varindersra
Please use the iLogic rule to change the unit with the steps below -
1. Create one unitless user parameter named "Test1"=1
2. Please copy and paste the code lines below in iLogic rule
Dim openDoc As Document
If Test1=1 Then
 oUOM_1=11269 'Millimeter Length
ElseIf Test1=2 Then
 oUOM_1=11272 'inch length
ElseIf Test1=3 Then
 oUOM_1=11273 'foot length
End If
3. When the change value of Test1, the unit in document will be changed.
For the other unit, please refer the attached spreadsheet.
River Cai
Inventor Quality Assurance Team
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
