Inventor General
Distinguished Mentor
swhite
Message 61 of 63 (543 Views)
Re: Inventor 2013 extremley slow in IDW's
03-06-2013 12:55 PM in reply to: rschader
Whenever someone says slow and inventor together in the same sentence bolted connections and derived parts are usually the first culprits. IMO bolted connections need overhauled, it is one of the biggest slowdowns inventor has, unless they have improved it in 2013?
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Distinguished Contributor
rschader
Message 62 of 63 (537 Views)
03-06-2013 02:31 PM in reply to: swhite
I wouldn't know, I don't use them. I'm one of those guys who puts a note on the drawing that says "Screw and Dowel to suit"! ;-)
Valued Mentor
rhasell
Message 63 of 63 (533 Views)
03-06-2013 03:45 PM in reply to: rschader
Bolted connections, never used them as I need more control over my BOM. I make my own "Bolted connections", hundreds of bolt/washer/nut assemblies in my own library, also set up as a 'Frequently used subfolder', not a Library folder.
Derived Assemblies, if I wanted a frontal lobotomy, it would not be via Inventor.
The issue with the slow down, was and has been solved by setting my Hardware to "Compatiblity" After each service pack/update I test the performance, but it has not been fixed yet, so I always go back to Compatibility.
Other than that, there are no performance issues at all. (Except for derived assemblies, this option should be removed from the software so that users are not tempted to use it.)
Reg
Autodesk PDS Ultimate 2015 Update 1 Build 159
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it fixes your problem.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
