Inventor General
Active Contributor
Message 1 of 13 (491 Views)
Accepted Solution
Inventor 2013 crashes upon assembly update
491 Views, 12 Replies
05-09-2013 05:00 AM
I'm running Inventor 2013 professional and I'm working on a project in wich I'm re-using some subassemblies in other assemblies. I've made some changes to the sub-assemblies when re-using them so I've copied the parts affected in design assistant.
Now to the problem. At some point in the project I've must have done something wrong when making a change to a re-used subassembly. Now every time I open one of my three major assemblies I get a message that changes have been made to some components (see attachment) and are asked if I want to update the assembly. When clicking YES Inventor crashes, every time.
I really hope this problem can be solved since I noticed that the back-up of my project is corrupt as well.
Kind regards,
Alex
Active Contributor
Message 2 of 13 (466 Views)
Re: Inventor 2013 crashes upon assembly update
05-10-2013 05:42 AM in reply to: alexander.o.pettersson
anyone?
Employee
Message 3 of 13 (466 Views)
05-10-2013 06:22 AM in reply to: alexander.o.pettersson
Hello Alex,
Thank you so much for reporting this issue. Can you please try few things?
  • Say ‘No’ to update while opening assembly/ When assembly opens, Go to ‘Manage’ tab/ Click on ‘Rebuild all’ / then save the assembly.
If this does not helps
  • While opening an assembly click on ‘Options’ command in the ‘Open’ dialog box/ Set LOD to ‘All component suppressed’/ Open the assembly/ Set active LOD as ‘master’ or your custom LOD/ Click on ‘Rebuild all’ / then save the assembly.
I hope this helps. If not, Can you please provide your dataset to me for more investigation?
Thank you,
Maulik R Patel (maulikr.patel@autodesk.com)
SQA Engineer, Inventor
Manufacturing Group
Autodesk, Inc.
Employee
Message 4 of 13 (453 Views)
05-10-2013 01:38 PM in reply to: alexander.o.pettersson
Hi! When Inventor crashes, did you submit crash reports? If yes, please send me a private email to (johnson.shiue@autodesk.com) so I can find the reports you submitted. If no, please submit the crash report and let me you when you are done.
With the crash reports, it is easier to tell where the problem is without having your dataset. If your dataset is needed to reproduce the crash, I will let you know.
Many thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Autodesk, Inc.
*Expert Elite*
blair
Message 5 of 13 (443 Views)
05-10-2013 09:14 PM in reply to: johnsonshiue
Are all the sub-assemblies fine? Have you opened each sub and verified that each one is fine.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Active Contributor
Message 6 of 13 (430 Views)
05-12-2013 03:33 AM in reply to: maulik_patel
Hi Maulik,
Thank you for the answer.
I followed the first instructions and it seems to have solved the problem, phew.  What does the rebuild all actually do?
/Alex
Active Contributor
Message 7 of 13 (424 Views)
05-12-2013 03:36 AM in reply to: johnsonshiue
Hi Johnson,
Yes I did. Do you still want me to send you an e-mail even though the problem is solved?
Employee
Message 8 of 13 (400 Views)
05-13-2013 06:13 AM in reply to: alexander.o.pettersson
Hi Alex,
I am glad that your problem got solved. ‘Rebuild All’ regenerates whole assembly file and updates all components in it(including those not needed an update).
Manufacturing Group
Autodesk, Inc.
Employee
Message 9 of 13 (392 Views)
05-13-2013 07:15 AM in reply to: alexander.o.pettersson
Hi! I am so glad to hear the issue is resolved. It seems like there was an issue earlier which got fixed by later update/SPx. Even though I have not see the crash, I believe it should be the case. Rebuild All basically computes the assembly from bottom to top based on given assembly constraints and updated part geometry. If a part geometry needs to be computed, it will be recomputed along with the command.
If you see other issues, please feel free contacting me.
Thanks!
Mechanical Design
Autodesk, Inc.
Active Contributor
Message 10 of 13 (192 Views)
11-12-2013 04:10 AM in reply to: johnsonshiue
I've tried both of the suggestions in the above post and i still have not been able to update my assembly. Help would be greatly appericated.
Inventor Pro 2014
nivida k6000
24 G RAM
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
