Inventor Forum
Inventor 2013 SP1
94 REPLIES 94
Message 1 of 95
2997 Views, 94 Replies
Inventor 2013 SP1
Inventor 2013 SP1 is up!
94 REPLIES 94
Message 2 of 95
DarrenP
i found this in the read me: Edit Family table in Excel 2013 is supported
is autodesk supporting office 2013 beta or this a typo?
DarrenP
Message 3 of 95
in reply to: DarrenP
Beats me.
Message 4 of 95
mrattray
I installed the 64bit version onto my machine, no problem.
I tried to install the 32bit version onto a colleagues computer and it popped up a message box asking for installation media.
Is this normal? I have the original installers on my hard drive still. Is that why mine worked and his failed? Is it a 64 bit vs 32 bit (I doubt it)? Is it because I have the full PDS Premium and he only has a standalone Inventor install? Is that you John Wayne?
Mike (not Matt) Rattray
Message 5 of 95
Installed here on a 32 bit machine, did not ask for media.
Message 6 of 95
jdits7
Just did a blog post about this, all information on one page,
http://inventortopix.blogspot.com/2012/09/inventor-2013-service-pack-1.html
jdits7
Autodesk Inventor Certified Professional
Blog - http://www.inventortopix.com
Twitter - @InventorTopixJD
Message 7 of 95
SBix26
Won't install on two machines so far-- 1402 error that it can't write to registry (even though I'm logged in as administrator, same account that I used to install originally).  Uninstalling and reinstalling from updated deployment-- I'll let you know Monday what happens.
Message 8 of 95
mrattray
in reply to: SBix26
Maybe I should roll back now...
Message 9 of 95
Installed here on a 64 bit machine, no problem.
Took 2 tries on a 32 bit machine, uninstalled SP1 and did a reboot, 2nd time was OK.
Message 10 of 95
vmcarbonneau
Anyone having problems with SP1 ?
This afternoon, it crashes 3 times when saving.
Message 11 of 95
in reply to: vmcarbonneau
Have you installed SP1?
Message 12 of 95
vmcarbonneau
Just did it, inventor was stable, now it's super unstable
Message 13 of 95
Did you have any errors during the install?
I had a machine have errors about not being able to close Windows Explorer, on this machine I uninstalled, re-booted, and then it was OK.
Message 14 of 95
vmcarbonneau
No error displayed when installing SP1, I will try to do a clean reinstall of Inventor then SP1. Will see if it solves the problem
Message 15 of 95
blair
No problems with install or IV. Inventor actually seems faster.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 16 of 95
in reply to: blair
Yes, seems a little faster here too.
Message 17 of 95
ChrisMitchell01
in reply to: SBix26
Sam,
A 1402 error indicates that you do not have permissions to write to a specific key in the registry. In the error it should tell you where it is trying to write to. You'll need to run regedit, find that key, Rt click go to permissions & ensure that Everyone has Full permission.
If that does not fix it then Set “Everyone” full permission to : HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 18 of 95
jdits7
Install went fine on 64-bit, don't have any machines that run 32-bit anymore, so not sure there. Inventor seems a little faster, will know more after today.
jdits7
Message 19 of 95
SBix26
in reply to: ChrisMitchell01
I no longer have a record of the specific path that was mentioned, but 2013 is the first version in which this has happened (all the way back to 5.3).  The administrator account that I am using to install the SP is the same one I used for installing 2013 RTM, and therefore the account which created that section of registry.  It works on some machines, or perhaps in some circumstances, not on others.  But I have uninstalled and reinstalled from an udated deployment with no issues on the machines that threw the error.
Message 20 of 95
telambert
in reply to: SBix26
It looks like that SP1 has been removed from the download area????
I just downloaded and installed it this morning and now the page is missing.
