Inventor General
jwagner
Message 1 of 9 (2,533 Views)
Inventor 2013 DE: BUG: Export IDW to AutoCAD DWG: Lines/Spline in the drawing.
2533 Views, 8 Replies
09-03-2012 09:53 AM
Problem:
Samplemodel:
1. open baugruppe1.idw > Save copy as: AutoCAD DWG
2. open DWG in ACADM 2013
Result:
Employee
jingyi.liu
Message 2 of 9 (2,509 Views)
Re: Inventor 2013 DE: BUG: Export IDW to AutoCAD DWG: Lines/Spline in the drawin
09-03-2012 06:08 PM in reply to: jwagner
Hi Jwagner
I reproduced your issue, it definitely is a bug, thanks for your report, I will log it as a defect.
Inventor Professional 2015
Jingyi Liu
Quality Assurance Team
jwagner
Message 3 of 9 (2,479 Views)
09-04-2012 02:58 AM in reply to: jingyi.liu
Hi Jingyi Liu,
Thank you!
Jürgen Wagner
German Autodesk Inventor FAQ
Active Member
lark22
Message 4 of 9 (2,038 Views)
01-08-2013 05:38 AM in reply to: jwagner
The same thing happens when exporting from Inventor 2013 .dwg to Autocad .dwg
Member
saso
Message 5 of 9 (1,971 Views)
01-22-2013 12:13 AM in reply to: jwagner
did anyone find a solution for this? It's already logged with development from August 2013 but still no solution.
Sašo.
Employee
jingyi.liu
Message 6 of 9 (1,965 Views)
01-22-2013 12:39 AM in reply to: jwagner
Hi, All
It seems many users are blocked by the exporting issue. Regarding the data attached in previous post, there is a solution to address the issue. But please pay attention, below change on exporting setting will impact all spline objects, it will replace spline with polylines.  We can't guarantee the results for any cases. Please try belows only when you face exporting issues.
The way to
  • Click option when export AutoCAD dwg file
  • Click next until you see "save configuration" button
  • Select folder and name the file, exit the exporting.
  • Open the configuration file by notepad, find the line " REPLACE SPLINE=NO", change the NO with YES, save the file.
  • Repeat the exporting and click option, but this time load the configuration file you have modified.
  Save exported AutoCAD DWG file, and check the result.
If you still can't solve the issue after changing, please send your dataset to us, it will be very helpful for development team to get the final solution.
Thanks in advance.
Jingyi Liu
Member
saso
Message 7 of 9 (1,961 Views)
01-22-2013 12:50 AM in reply to: jingyi.liu
I works!
I wish someone told me this half year ago... I was looking for that "replace splines" option everywhere but in that location.
Thanks.
Sašo.
^_^clovis^_^
Message 8 of 9 (70 Views)
07-01-2014 11:22 PM in reply to: jingyi.liu
I'm using Inventor 2014 pro and the problem remains :
left : inventor | right : autocad and (part) modified ini
Thanks for any help
^_^clovis^_^
Message 9 of 9 (43 Views)
07-02-2014 06:09 AM in reply to: ^_^clovis^_^
Until a patch is available, I can't bear having a durty dwg :smileymad:
(defun c:cll( / acadob count aob listSpline alay lPoints nbp p1 p2 okList)
	;remove non Spline
	(setq acadob(vla-get-activeDocument(vlax-get-acad-object)))
	(setq okList
		(ssget "x" '( 	(-4 . "<NOT")(-4 . "<OR")
						(0 . "SPLINE")
					(-4 . "OR>")(-4 . "NOT>"))
	;change Spline
	(setq count 0)
	(repeat (sslength okList)
		(setq aob (vlax-ename->vla-object(ssname okList count)))
		(vla-put-visible aob 0)
		(setq count (1+ count))
	(defun makeLine ( point1 point2 lay / )
		(entmake
			(list
				'(0 . "LINE")
				'(100 . "AcDbEntity")
				(cons 8 lay)
				'(100 . "AcDbLine")
				point1
				point2
	(Prompt "\nSelect Spline to change..")
	(setq listSpline (ssget '((100 . "AcDbSpline"))))
	(setq count 0)
	(repeat (sslength listSpline)
		(setq aob (vlax-ename->vla-object(ssname listSpline count)))
		(setq alay (vla-get-layer aob))
		(setq lpoints (vlax-safearray->list(vlax-variant-value(vla-get-controlpoints aob))))
		(setq nbp (length lPoints))
		(setq 	p1 (list 	10
							(nth 0 lPoints)
							(nth 1 lPoints)
							0.0)
				p2 (list	11
							(nth (- nbp 3) lPoints)
							(nth (- nbp 2) lPoints)
							0.0
		(makeLine p1 p2 alay)
		(setq count(1+ count))
	(setvar "cmdecho" 0)
	(command "erase" listSpline "")
	(setvar "cmdecho" 1)
	;reset
	(setq count 0)
		(vla-put-visible aob -1)
	(princ)
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
