Inventor General
chrishutchinson6900
Message 1 of 6 (1,106 Views)
Inventor 2013 Custom Materials Library Creation
1106 Views, 5 Replies
04-24-2012 12:45 PM
Is there a good source of material mechanical properties on the internet?  I have been creating a custom material library with the materials I normally use and I've just been duplicating a material from the supplied libraries to create mine with a name change only.  I'd like to include the correct mechanical properties if I could find a source of information that has all the properties in the format that the Inventor 2013 materials editor requires.
Chris Hutchinson
Curtis_Waguespack
Message 2 of 6 (1,102 Views)
Re: Inventor 2013 Custom Materials Library Creation
04-24-2012 12:52 PM in reply to: chrishutchinson6900
Hi chrishutchinson6900,
Here is one source:
http://www.matweb.com/
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
mcgyvr
Message 3 of 6 (1,094 Views)
04-24-2012 01:30 PM in reply to: Curtis_Waguespack
matweb is the best I've found.. I use it all the time.. Be prepared to do some annoying math to get the correct units for Inventor.
I wish Inventor had more of a dropdown next to each value allowing you to enter any of the common unit formats and it would do the conversion for you..
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2014 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Mentor
RayFeiler
Message 4 of 6 (1,063 Views)
04-25-2012 10:25 AM in reply to: mcgyvr
I use convert.exe
http://wscope.com/convert.htm
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
mrattray
Message 5 of 6 (1,058 Views)
04-25-2012 10:43 AM in reply to: RayFeiler
I typicaly just use google. It's quite capable for most common math and conversions. I downloaded you converter though, it looks useful.
Mike (not Matt) Rattray
Valued Contributor
Message 6 of 6 (790 Views)
09-25-2012 03:13 AM in reply to: mcgyvr
For that purpose, you can change units for whole material library, then edit it, and change units back. You can do that in material library bottom left options.
Factory design suite 2013 premium
Some old workstation ...
Fancy HP LCD
:smileyhappy:
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
