Inventor Forum
Inventor 2013 Custom Materials Library Creation
5 REPLIES 5
chrishutchinson6848
1688 Views, 5 Replies
Is there a good source of material mechanical properties on the internet?  I have been creating a custom material library with the materials I normally use and I've just been duplicating a material from the supplied libraries to create mine with a name change only.  I'd like to include the correct mechanical properties if I could find a source of information that has all the properties in the format that the Inventor 2013 materials editor requires.
Chris Hutchinson
5 REPLIES 5
Hi chrishutchinson6900,
Here is one source:
http://www.matweb.com/
I hope this helps.
Curtis
mcgyvr
in reply to: Curtis_Waguespack
matweb is the best I've found.. I use it all the time.. Be prepared to do some annoying math to get the correct units for Inventor.
I wish Inventor had more of a dropdown next to each value allowing you to enter any of the common unit formats and it would do the conversion for you..
Ray_Feiler
in reply to: mcgyvr
I use convert.exe
http://wscope.com/convert.htm
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
mrattray
in reply to: Ray_Feiler
I typicaly just use google. It's quite capable for most common math and conversions. I downloaded you converter though, it looks useful.
Mike (not Matt) Rattray
streharg
in reply to: mcgyvr
For that purpose, you can change units for whole material library, then edit it, and change units back. You can do that in material library bottom left options.
PDSU 2016
4790K, 32 Gb ram, GTX 960 ...
Fancy HP LCD
