Inventor General
*Pro
sbixler
Message 11 of 18 (527 Views)
Re: Inventor 2013 Crashes When Clicking Draw Operation in Sketch Mode
10-25-2012 05:29 AM in reply to: Iapetos
Sounds as if the whole user section of the registry (the one you deleted) didn't get re-created properly.  Try deleting that registry key again, and while you're at it, check the permissions on the whole Autodesk key.
Member
Iapetos
Message 12 of 18 (519 Views)
Nevermind, I figured it out. Inventor created a Reg folde...
10-25-2012 07:15 AM in reply to: SteveKS
Nevermind, I figured it out. Inventor created a Reg folder named RegistryVersion0.0. Deleting that and restarting Inventor a few times solved it. I got my color options back also.
P.s. Didn't see your post until i posted this response. Thanks for your help!
Member
sm180
Message 13 of 18 (449 Views)
12-04-2012 05:24 AM in reply to: SteveKS
Please help, not sure where or how to find:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion17.0
Thanks in advance
*Pro
sbixler
Message 14 of 18 (442 Views)
12-04-2012 06:51 AM in reply to: sm180
I don't have time to give you a tutorial on the Windows registry (if I even knew enough to do so!), so you may want to do some research yourself.  Suffice to say that every aspect of operating your computer and all its installed applications is directed by the registry.  Editing it manually is sometimes useful, but one wrong move can hose an application, or the entire computer.  The registry editor is "regedit.exe" (clever name, huh?).
The registry is a hierarchical structure, sort of like folders and files on your hard drive.  Just be careful not to change anything that you're not sure of.  But you can delete the key noted above (Version 17.0) and Inventor will re-create it the next time you run it.
Member
sm180
Message 15 of 18 (436 Views)
12-04-2012 09:25 AM in reply to: sbixler
Thank you, I managed to delete it no problem. First time coming across regedit.exe but it was user-friendly enough to work without any research and it has fixed the crashing problem so I'm very grateful!
jkhoylman
Message 16 of 18 (357 Views)
02-24-2013 10:33 AM in reply to: Iapetos
How do you get to the registry?
*Pro
sbixler
Message 17 of 18 (349 Views)
02-24-2013 12:11 PM in reply to: jkhoylman
Read my previous post above...
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
New Member
inked8
Message 18 of 18 (116 Views)
11-13-2013 12:04 AM in reply to: SteveKS
This solution worked 100% I had exactely the same issue, so glad I dont have to do a re-install
:smileyhappy:
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
