Inventor General
Message 1 of 34 (3,281 Views)
Inventor 2013 Crashes Instantly
3281 Views, 33 Replies
09-27-2012 08:08 AM
Hello everyone,
Never hoped I would use one of this forums, but it seems like I need your help. Did I mention? - I NEED YOUR HELP!
So this was really weird. I installed 2013 version about a month ago and it worked great! Haven't used it for 2 weeks and yesterday, tried opening it, but when I tried creating a new file it crashes. I was surprised. So I tried again, and it still crashed. Then I tried opening an existing file and guess what? It crashed. I tried reinstalling 2013 version. Keeps crashing. It only opens the home screen and once I say create a part file or open a file and after I choose the file in the location, it crashes again. I am so disappointed.
Also tried to install 2012 version, but it wouldn't install it at all!!! It refuses to install anything and shows error.
I am really confused about what happened. Don't seem to have any reasonable explanation.
Hope you all can help!
Let me know if you need to know more, I will try to explain better.
Nikita
Distinguished Mentor
Message 2 of 34 (3,272 Views)
Re: Inventor 2013 Crashes Instantly
09-27-2012 09:13 AM in reply to: n.k.timofeev
Are you getting any error messages?
Please post screen shot of crash, if possible.
John Retzlaff
Message 3 of 34 (3,272 Views)
09-27-2012 09:15 AM in reply to: john.retzlaff
Yeah I do. But I won't have access to it until later tonigh.
Message 4 of 34 (3,261 Views)
09-27-2012 09:38 AM in reply to: n.k.timofeev
My guess is at this point you will need to search Google for Autodesk Clean Uninstall instructions.
Update and run virus scanner.
Reinstall with virus scanner and UAC turned off.
When you get it reinstalled and verify that all is well - Create a Windows Restore Point.  (and faithfully do this after install of any new program)
Next time restore to date when it worked.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 5 of 34 (3,234 Views)
09-27-2012 04:42 PM in reply to: n.k.timofeev
Here is a screen sht of the error report.
Member
Message 6 of 34 (3,074 Views)
10-17-2012 07:57 PM in reply to: n.k.timofeev
Has a solution been found for this? I'm experiencing the exact same problem as OP to the letter. Inventor Pro 2013 worked perfectly a month ago then last week everything went south.
Message 7 of 34 (3,071 Views)
10-17-2012 08:03 PM in reply to: ckesler
Unfortunately NO!!! I tried many things:
-Uninstalling Inventor with the program Uninstaller
-Deleting Inventor folders in various locations on my drive
-Erasing directory in HKEY
But after hours and hours trying to find a solution nothing worked. Now it's even better - I can't even uninstal the Inventor itself.... Program can't be found. I can't run it. However, during the installation, it shows that the Inventor is present on my computer.
Very interesting situation...
I would suggest not to repeat the steps I did. I keep trying to find time to call the customer service and help me fix it, but never have free time.
Let me know if you find a solution.
Member
Message 8 of 34 (3,064 Views)
10-17-2012 08:21 PM in reply to: n.k.timofeev
I have two budies in the same situation. I wonder if a Windows Update or something caused the problems? Everything worked fine until a couple weeks ago.
If I find a solution I will gladly let you know.
Employee
Message 9 of 34 (3,016 Views)
10-18-2012 01:29 PM in reply to: n.k.timofeev
From the crash reports we've recieved from you, it appears that DirectX might not be properly installed on your systems.
Try running the dxdiag command - ideally you should have DirectX version11 installed for 2013, (although it has been tested back to version 9). If you don't have v11 then see http://support.microsoft.com/kb/179113
Depending on your specific h/w you might also need to update your graphics driver too, after the DirectX upgrade.
Chris
Chris Mitchell
Inventor Customer Enagagement Team
Member
Message 10 of 34 (2,952 Views)
10-21-2012 05:19 PM in reply to: n.k.timofeev
I have attempted the Autodesk clean uninstall. Reinstalled the Inventor 2013. Ran dxdiag and attached is the report. Everything appeared to be up to date but I went ahead and attempted to update DirectX and drivers. Also installed recommended maintenance update also attached. Now when opening a file I no longer get error report Inventor just closes.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
