Inventor General
Valued Contributor
Message 1 of 6 (374 Views)
Inventor 2013, Bump not showing
374 Views, 5 Replies
06-26-2012 07:50 AM
I have a problem with only some parts.
Bump is not showing. Tryed all i can think of, but nothing helps.
Bump is not showing, when i use "Shaded" or "Shaded with edges".
But it shows if i use Raytrace.
Any got a solution?
See pictures.
Kind regards
Henrik Graversen
Employee
Message 2 of 6 (291 Views)
Re: Inventor 2013, Bump not showing
06-26-2012 10:05 PM in reply to: HenrikGraversen
Henrik,
Can you also post an actual ipt file with the problem ?
Chris
Chris Mitchell
Inventor Customer Enagagement Team
Autodesk, Inc.
Valued Contributor
Message 3 of 6 (275 Views)
06-27-2012 01:13 AM in reply to: ChrisMitchell01
Hi Chris
Here you go.
Henrik
wh
Message 4 of 6 (259 Views)
06-27-2012 04:16 AM in reply to: HenrikGraversen
I could see the bump, when moving EOP down from the top.
But when I reached Hole2, the bump disappeared. I can cycle that back and forth.
And if I change the hole type to non-threaded, bump is ok.
Same behavior occurs already with Hole1, but I've overlooked it. Extrusion4 behind Hole1 brings the bump back again.
Walter
Valued Contributor
subsales
Message 5 of 6 (228 Views)
06-27-2012 12:34 PM in reply to: HenrikGraversen
Hello Henrik,
I tried to to reproduce this issue on Inventor 2013. Its wrong behaviour.
I am confirming it and I will work with developer to solve this issue.
Actually thread is a bad guy here. Some how intventor disables bumps when thread will be applied to sheetmetal part.
There is a workaround for you in this case.
Simply move "Cut 3" in browser below "Hole 3". It will bring back bumps.
Let me know if more help is needed.
Thank you,
Maulik Patel
Employee
Message 6 of 6 (205 Views)
06-27-2012 01:22 PM in reply to: HenrikGraversen
I am sorry.I was logged with different account.
Thank you,
Maulik Patel
Maulik R Patel (maulikr.patel@autodesk.com)
SQA Engineer, Inventor
Manufacturing Group
Autodesk, Inc.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
