Inventor Forum
Inventor 2012 will not export PDF
3 REPLIES 3
nomiss05
317 Views, 3 Replies
I have Windows 7 with inventor 2012 and Today when I have my .idw up I can not export as PDF like usual. when the dialog box comes up the "save as type" field is blank. If i manually try to save ***.pdf I get a message that the extention type is not right and to try again. I have never had this problem before. I even manually installed the latest SP update and still get the same thing. I can export as other file types but when I select PDF I get errors. ANy help?
3 REPLIES 3
mrattray
in reply to: nomiss05
Exactly what method are you trying to use to save the PDF? Have you tried printing to a PDF file?
Mike (not Matt) Rattray
nomiss05
in reply to: mrattray
When I am in my drawing I go to the I < Export< PDF
Won't work even when I am in a part or assy
karthur1
Would help if you would tell what error you are seeing.  Screen shot would be good.
