Inventor General
Active Contributor
IS200
Message 11 of 16 (269 Views)
Re: Inventor 2012 loses focus, can't save
10-24-2012 04:23 PM in reply to: IS200
I have seen the taskbar icon change to 2 icons during these times, one says 'Autodesk Inventor', the other says 'Ad Applicaion Button' then, when Inventor comes back to life, the button is dead.
I don't think it is a graphics issue as I have the latest drivers installed on a Quadro 2000 card.
Could this be a problem associated with having multiple displays?
I have also noticed that Inventor now 'steals focus' from other programs. If I am on my 2nd monitor with another program as my active window and I mouse over Inventor it steals the focus away as soon as the stupid 'part number eye-candy box' pops up. Is there any way of stopping this from occuring as it is really annoying when I am typing an email and Inventor pulls focus away from my typing. If I don't notice straight away I am running all sorts of commands in Inventor.
I don't recall previous versions of Inventor having this problem. Is it a bug which has added with the new popup eye-candy?
*Pro
sbixler
Message 12 of 16 (254 Views)
10-25-2012 04:15 AM in reply to: IS200
Sorry, I'm out of ideas.  I've never experienced anything like this in any version of Inventor.  The multiple displays angle sounds the most likely, but someone with more experience in that area will have to jump in here.
Distinguished Contributor
nstalker
Message 13 of 16 (188 Views)
03-04-2013 09:07 AM in reply to: IS200
just wanted to let you know that you're not crazy.  I experience the exact same problem.  The only solution I have is to wait and eventually Inventor starts working again.  It just does a really poor job of communicating with Windows.  Windows thinks it is not responding but it's just thinking.  I would appreciate if Autodesk made a progress bar or something so you can tell that the application is not frozen.
Distinguished Mentor
Message 14 of 16 (184 Views)
03-04-2013 09:13 AM in reply to: nstalker
Yes, this is an issue that needs fixed. Usually a response window tries to open then goes to the background where it cant be accessed. This leaves you stuck and unable to respond to the querry you can't see. It does not always work, but if you double click where the I icon should be it will close the program and save a temporary rescue file. As I said, this does not always work, but beats redoing work if it does. Best of luck :smileyhappy:
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
nstalker
Message 15 of 16 (128 Views)
04-03-2013 12:37 PM in reply to: IS200
where is this temporary save file located?
Message 16 of 16 (126 Views)
04-03-2013 12:50 PM in reply to: swhite
This doesn't solve your problem of why and how to fix, but I can tell you that I save often enough that I am never concerned about retrieving any lost work.  I can quickly recreate 5 minutes of work.  Not that I save every 5 minutes, but that I don't not save anything that would take me more than 5 minutes to recreate. Not saying that I never crash.
If loosing work in the next second would be a significant hassle to recreate, I save.
I have never opened an oldversions file, except when helping others.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
