1) Inventor (2011) used to give me hits from this forum and other recources whenever I searched for something in the help, now all I get is the Wiki help. How do I fix it?
2) How can I make/force Inventor to use my internet browser of choice and not IE9? Is it even possible?
3) How do I switch off the cute little menu thingy that pops up everytime I want to extrude, or cut, etc? What was wrong with the old one, this new thing is just cluttering the desktop (and it's SLOW). Just realised I'm getting old cause I don't like the changes...
Cheers,
William
Solved by whunter. Go to Solution.
Hi whunter,
Here are a couple of links that will help with some of this:
http://inventortrenches.blogspot.com/2011/04/bring-back-classic-right-click-menu-in.html
http://inventortrenches.blogspot.com/2011/04/where-are-inventor-2012-tutorial-and.html
I hope this helps.
Curtis
Thanks, I actually found your posts after I calmed down after my intial post. Immensly frustrating, if someone asked me today if they should buy Inventor I would've said NO.
Anyway, I hope all these annoying things are sorted out with the service pack.
I'm still looking for a solution to search the forums from within Inventor, as per Inv 2011...
Found it, answer was in the forums all along. Not a nice solution (I'll give it half a mark):
So you have to search the forums 'manually', pity, it was nice to have the search function in one place.
Interestingly, Google gave much better results than the forum's built in search engine for the same search string, but that is probably to be expected. This works better than the built in forum search (type in a Google search box):
your query site:forums.autodesk.com
