Inventor Forum
Inventor 2012 Task Scheduler is not respoonding
1 REPLY 1
falkmassmann
548 Views, 1 Reply
Good day,
I´m having a problem with the Inventor 2012 Task Scheduler.
I´ve done a couple of migration tasks over the last 2 months, actually quite some big tasks on our Vault Server.
Now I´m getting no more access to the application, it´s either showing a message that the server is busy and not responding or the application starts up and sits for a minute in the task bar and then opens up but still I can´t click any menus or create a report to control the tasks I´ve done earlier.
But I need to check the last couple of tasks to see which files have been succesfully migrated and which are not.
I know that I can view the logfiles manually but that still leaves me with no more tasks that I need to run to fix our database and Inventor files.
Let the application run with administrator rights doesn´t help either, I´m at a loss here. What else could be done to get
the task scheduler back up running?
All the best
Falk
1 REPLY 1
falkmassmann
in reply to: falkmassmann
The only solution for me was replacing the database for the Task Scheduler with the original one from the installation.
For anyone having the same problem, make a copy of the recent *.mdb´s and look for the fresh database on your installation disk.
It seems Task Scheduler is not capable of doing large migration datasets under WinXP 64, after 8 to 10 tasks in the database the application becomes completely unusable.
The question is, what other tool can be used for migrating a vault with 75.000 files?
I answered that question for myself with None.
You will have to live with another Autodesk 80% solution, which is the Task Scheduler.
Best wishes
