Inventor Forum
Inventor 2012- Set Print Area
9 REPLIES 9
Message 1 of 10
varindersra
1882 Views, 9 Replies
Is it possible to set print area in Inventor assembly mode. I have a vertical tall assembly that I want to print. But, when I print it includes the Inventor background as well in the print & because of that I am not able to orient my assembly properly. So, is there a way to get rid of the background or set a print area while printing.
Thanks in advance!
Varinder
9 REPLIES 9
Message 2 of 10
mrattray
in reply to: varindersra
Try using the Windows Snippet tool to capture screen shots for printing.
Mike (not Matt) Rattray
Message 3 of 10
varindersra
in reply to: mrattray
Thanks for reply. I know I could do whatever I want using snapshot & MS Paint. But, I am looking for direct way of doing it from Invantor itself.
Message 4 of 10
mrattray
I don't know of an easy way of getting what your looking for using Inventor alone. The "Snippet" Windows tool will work great for this, try it.
I used it to take this creen shot of a part in Inventor:
Message 5 of 10
mpatchus
Here's what I do when I need a real quick print of an assembly.
Try dragging your inventor window to approximate the size of the paper.
Zoom to the level of what you want to appear in the print.
Adjust your print setup and do a print preview.
You should get something like this.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 6 of 10
varindersra
in reply to: mpatchus
Thanks for reply. That kind of works for me. But, it would be better if there's an option to set print area or remove background while printing or exporting.
Thanks a lot!
Varinder
Message 7 of 10
blair
Or use the Autodesk Exchange Apps, there is a free App called "Screenshot". In the very upper portion of the Inventor menu screen (top RH) is fully looking two-tone blue X, clicking on this will open the Apps website.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 8 of 10
SBix26
Concerning your background printing: printing from a model file will include the background if the App Options is set to 'Gradient', and will not include the background if set to '1 Color'.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 9 of 10
varindersra
in reply to: SBix26
Yes, even though by selecting one color the background doesn't show up in print but it still adds the background area into the print. That what I want to avoid. See attachment for the issue. My print is cming out as shown below.Untitled.jpg
Message 10 of 10
SBix26
Then try rendering in Studio.  It's been a long time since I've done it, but I believe that if you save your render to .png format, you have the option to select Alpha Channel, which eliminates the background.  But that's extra steps to enter the Studio environnment, set up the render, execute, then open the resulting file and print.  But it is the only way I know of to eliminate the background.
Sam B
