Inventor Forum
Inventor 2012 SAVE COPY AS DWG Ilogic Code Error
4 REPLIES 4
rthapa
2597 Views, 4 Replies
HELP!
Are there anyone out there using Inventor 2012 and using ilogic rule or VB codes to auto Save Copy AS DWG?
My old code error out when debugging. The exact error is on this code line:
DWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Autodesk has agreed that this code does not work on Inventor 2012 and that the development is working on it. This code is part of the Snippets built in Inventor iLogic Rule Browser.
Someone must have an answer or workaroudn this problem out there. Help.
4 REPLIES 4
jeffrey.sun
in reply to: rthapa
Hi Rthapa,
I reply the iLogic issue in this thread (http://forums.autodesk.com/t5/Autodesk-Inventor/EXPORT-TO-DWG-ILOGIC-RULE-DOES-NOT-WORK/m-p/3283079/...)
If you want to do the export work with VB or C# application, it is also possilbe, and it would be easy to implement export automation. The detailed steps is stated below.
Dwg out in VB application
  • Create a VB console project
  • Add COM referece "Autodesk Inventor Object Library";
  • Add the code to do the dwgout work.
Imports Inventor
Module Module1
SubSaveAsDwg()
DiminventorTypeAsType = System.Type.GetTypeFromProgID("Inventor.Application")
DimInvAppAsInventor.Application = System.Activator.CreateInstance(inventorType)
IfInvAppIsNothingThenThrowNewException("Could not start Inventor.")
EndIf
' Dim InvApp As Inventor.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
'InvApp.Visible = True'We must use true. Otherwise it will crash when do dwgout.DimInvDocAsDrawingDocument = InvApp.Documents.Open("C:\drawing.idw", True)
IfInvDocIsNothingThenThrowNewException("Could not open idw file.")
EndIf
' Get the DWG translator Add-In.DimDWGAddInAsTranslatorAddIn = InvApp.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
IfDWGAddInIsNothingThenThrowNewException("Could not access DWG translator.")
EndIf
DimtranslationContextAsTranslationContext = InvApp.TransientObjects.CreateTranslationContexttranslationContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
DimoptionsAsNameValueMap = InvApp.TransientObjects.CreateNameValueMap
IfDWGAddIn.HasSaveCopyAsOptions(InvDoc, translationContext, options) Then
options.Value("Export_Acad_IniFile") = "C:\dwg.ini"
DimdataMediumAsDataMedium = InvApp.TransientObjects.CreateDataMediumdataMedium.FileName = "C:\test2.dwg"
CallDWGAddIn.SaveCopyAs(InvDoc, translationContext, options, dataMedium)
EndIf
EndSub
SubMain()
TrySaveAsDwg()
CatcheAsExceptionConsole.Write(e.Message)
EndTryEndSub
End
Module
Jeffrey Sun
SW Engineer
Manufacturing Industry Group
Autodesk, Inc.
jeffrey.sun
in reply to: jeffrey.sun
Dwg out in c# application
  • Create a C# console project
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace dwgOutAddInCSharp
classProgram
publicstaticvoidSaveAsDwg()
System.TypeinventorType = System.Type.GetTypeFromProgID("Inventor.Application");
Inventor.ApplicationInvApp = System.Activator.CreateInstance(inventorType) asInventor.Application;
if (null == InvApp)
thrownewException("Could not start Inventor.");
// We must use true. Otherwise it will crash when do dwgout.
Inventor.DrawingDocumentInvDoc = InvApp.Documents.Open("C:\\drawing.idw", true) asInventor.DrawingDocument;
if (null == InvDoc)
thrownewException("Could not open idw file.");
Inventor.TranslatorAddIndwgAddIn = (Inventor.TranslatorAddIn)InvApp.ApplicationAddIns.get_ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}");
if (dwgAddIn == null)
thrownewException("Could not access DWG translator.");
Inventor.TranslationContexttranslationContext = InvApp.TransientObjects.CreateTranslationContext();
translationContext.Type = Inventor.IOMechanismEnum.kFileBrowseIOMechanism;
Inventor.NameValueMapoptions = InvApp.TransientObjects.CreateNameValueMap();
if (dwgAddIn.get_HasSaveCopyAsOptions(InvDoc, translationContext, options))
options.set_Value("Export_Acad_IniFile", @"c:\dwg.ini");
Inventor.DataMediumdataMedium = InvApp.TransientObjects.CreateDataMedium();
dataMedium.FileName = @"C:\test2.dwg";
dwgAddIn.SaveCopyAs(InvDoc, translationContext, options, dataMedium);
staticvoidMain(string[] args)
try
SaveAsDwg();
catch (System.Exceptionex)
System.Console.Write(ex.Message);
Jeffrey Sun
SW Engineer
Autodesk, Inc.
rthapa
in reply to: rthapa
Thank you. Problem is resolved now.
My findings:
1. Migrating 2011 IDW Standard Template with embedded iLogic Rule to 2012 version does not work and corrupts the template file internally some how.
2. DWGOUT.INI file was in specified directory. Missing DWGOUT.INI file does crash the iLogic rule
3. Deleting iLogic Rules from migrated template, Save Copy AS to new file then add iLogic Rules back in Solved the problem.
4. DWGOUT.INI was already in place and was not modified.
luigi.trabacchin
in reply to: rthapa
i've a similar issue in vb.net i'm trying to do an export from an iventor idw to an autocad dwg, and i'm trying to do this parallelly with the TPL of .net and i get this COMexception "Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))"
any suggestion ?
i've tried generating a new template file, but maybe i've done smthing wrong ...
