Inventor Forum
Inventor 2012 Pro - flat pattern for a solid
2 REPLIES 2
jrm_1971
589 Views, 2 Replies
Is there a way, in an .idw (drawing file) to create a flat view (unrolled) of a cylindrical solid? NOT to be confused with sheet metal. This is from a solid .ipt. Either that or create a flat pattern of a solid cylinder that IS NOT SHEET METAL?
2 REPLIES 2
Mark_Wigan
in reply to: jrm_1971
ok well not too sure if this still falls within your allowable methodology, but maybe if you want to, you could derive the cylinder into a new sheet metal part, ipt (choose import as a surface). Then just thicken the outer skin, rip it and flatten it.
when you save the file, just call it the same file name as the main part but add a postfix to the name to indicate that it is related information.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
JDMather
Sheet metal is just a term for a catagory of specialized tools.
Attach your file here.
The CADWhisperer YouTube Channel
