Inventor Forum
Inventor 2012 - Create Ordinate Sets from Opposite Edges without Multiple Zeros?
10 REPLIES 10
Message 1 of 11
tdswanson
1555 Views, 10 Replies
Hey everyone:
I'm detailing a simple square plate with a good number of holes in it.  I create an ordiate set running vertically along the LH edge and select the holes that are close to that side.  Origin is the lower LH corner.  Works great, easy.
The holes that are closer to the RH side though I'd like to show on that side.  So I go to create a second ordinate set for the RH side and choose the lower RH corner as the origin and choose my holes that are close to that edge.  The 2nd set will automatically show a second "0.000" dimension on the bottom edge and I can't supress it by right clicking.
Is there a better way to do this?  What I've done now is to not use a set but just choose ordinate dimension and go from the opposite edge, which works....  But alignment is better with a set.  Suggestions?
10 REPLIES 10
Message 2 of 11
SBix26
in reply to: tdswanson
Same here.  You can hide the 0.000 dimension value, but not, so far as I can tell, the extension line.  I end up using individual ordinate dimensions as you have described.
Wish list item: be able to hide the origin member of all but one Ordinate Dimension Sets which run the same direction in the same view.
Message 3 of 11
innovatenate
Ordinate Sets have individual, custom origins defined in each annotation feature. The Ordinate tool can be more flexible in some scenarios.
In Ordinate dimensions, it is easier to modify a single dimension in the set. A numeric annotation for the origin is not required. The origin symbol can even be hidden if preferred.
The dimension > Arrange feature is the feature you are looking for to get dimension alignment like an ordinate set. I've attached a quick video of the features I'm describing above.
Nathan Chandler
Principal Specialist
Message 4 of 11
SBix26
in reply to: innovatenate
You've described exactly the workaround that we are currently using.  But the OP and I are both wanting the benefits of an ordinate set (automatic alignment, jogged leaders where needed, etc.), but being able to place some of the members on the opposite side of the view, either by creating a second set and hiding the zero value, or by tagging specific members of a set and defining a secondary location for them.
Not suggesting that this is a simple programming change, but does it make sense?
Message 5 of 11
japike
in reply to: SBix26
This works in 2011 & 2013 (we skipped 2012):
First use the ordinate dimension tool to select your origin, click continue and then cancel.
Select the ordinate dimension set tool and place your first set of dimensions.
Then repeat using the ordinate dimension set tool to place the second set of dimensions without making the zero selection.
Is that what you are looking for?
Peace,
Jeff
Inventor 2022
Message 6 of 11
SBix26
in reply to: japike
Great! This works, but not quite as you described.  You can't avoid making the zero selection, but if you pick the actual geometry that you want to dimension as the zero point, you can go back afterwards and right click on the set, choose Options > Use Origin Indicator.  This accomplishes exactly what I wanted with only the smallest of workarounds.
Tdswanson, does this work for you?
Message 7 of 11
japike
in reply to: SBix26
Sam,
Check your dimension styles. On the "Options" tab there is a check box for "Use Origin Indicator" under "Ordinate Dimension Origins" (It looks like the origin symbol".
Peace,
Jeff
Inventor 2022
Message 8 of 11
SBix26
in reply to: japike
Ah, yes.  I'll have to ponder the other implications of doing that, but it might just work that way for us.
Thanks for the help.  I've learned my one new thing for today!
Message 9 of 11
tdswanson
in reply to: SBix26
Maybe I'm missing the a step, but this doens't seem to work for me.  Here's the steps I'm following:
1. Choose ordinate set, prompted to choose an origin.
2. Pick a corner of a square plate for the origin.  It'll show the big target there.
3. Choose some holes for a dimension set, choose continue, choose create.  Escape.
4. Click ordinate set again.
5. Prompted to choose origin, choose the same corner point as before.
6. Pick some other holes to dimension.
7. Choose continue, drag new set to the opposite side of the block.
8. Choose create.  I now have (2) 0.000 dimensions pointing to the corner of the block.
9. Right click on the second set, options>Use Origin Indicator is unchecked.  Click it and nothing visually changes.
10. Right click on the second set, options>Hide origin indicator hides the "target" icon, but I still have (2) 0.000 dimensions.
When right clicking on one of the 0.000 dims, I don't have the option to delete member.  Am I missing something?
Thanks for looking into this guys!
Message 10 of 11
SBix26
The thing you're missing is that your first pick doesn't need to be the zero.  If the dimension style is set to "Use Origin Indicator", it will measure from the origin.  Even if you don't have a view origin when you place the ordinate set, when you eventually set one, the ordinate sets will update to measure from that location.
Message 11 of 11
tdswanson
in reply to: SBix26
Ahh.  I see.  So you still get prompted to choose the origin for the second set, but the point you pick seems to have no impact on what happens after that.  All the dimensioned geometry seems to refer back to the origin point chosen when making the first set.  Seems like this is the ticket.
Thanks again for all your help everyone!
