I have just started a new job that uses inventor 2011 and at my previous job I was using inventor 2012-2014. The newer version of inventor had i-logic forms which I could create to use as a configuration for parts, I was wondering how I could achieve this in inventor 2011. I need to be able to set nozzle height and angle location for balance, thanks.
Not enough detail in your question to suggest a possible solution..
You said "configurations" ... can you use iparts/iassemblies instead?
I need a way to configure a base assembly or part per costumer specs. The company I now work at creates water tanks and filtration system, I am working on what they call a balance tank that feeds the filtration system its water supply. The tank has 10 nozzles on it that the customer can specify the height and degree of orientation around the tanks. I am looking for a way to use a base set up and just specify the nozzle hieght and angle location and have every thing change and be able to save the assembly and parts as new part numbers that use the customer purchase order number. The tanks are made as a base shell and the holes are then cut out per customer specs. for the nozzel location.
I have just started at this company so I do not have much pull yet, I am familiar with the concepts that you mentioned, but just need some help to get pointed in the right direction and started as I am not sure how to approach it.
