Inventor General
Active Member
SpitfireRcp
Message 1 of 9 (2,287 Views)
Inventor 2011 Animation Rendering
2287 Views, 8 Replies
07-29-2010 09:41 PM
After running a rendering for an animation, I opened up the .wmv file to see that everything was a blur. The anti-alias was set to high,  screen resolution to 1024x768, frame rate 25, and 1500 kbps. Is there something that I am doing wrong?
Active Member
SpitfireRcp
Message 2 of 9 (2,254 Views)
Re: Inventor 2011 Animation Rendering
08-03-2010 03:33 PM in reply to: SpitfireRcp
I guess no one knows...
Employee
bill.bogan
Message 3 of 9 (2,248 Views)
08-03-2010 03:54 PM in reply to: SpitfireRcp
were you doing much else while the rendering was going on? I've had periodic questionable results from wmv and try to avoid using it unless I have no alternative.
Have you tried rendering to AVI ? If yes...
  • what was the outcome?
  • what codec do you use?
  • Is the animation intense/complex or simple (like a camera turntable)?
I'm trying to get a picture of what may be involved.
Thanks.
Bill Bogan
Principal Content Developer
Design, Lifecycle, and Simulation
Active Member
SpitfireRcp
Message 4 of 9 (2,248 Views)
08-03-2010 03:59 PM in reply to: bill.bogan
I wasn't doing anything while the computer was running, I even turned off my wireless internet. I didn't want to render to an AVI because of the whole codec ordeal, I have no idea which to use and I want to be able to view it easily in like windows media player and not have to download a special program like divx. I can try and render it to an AVI if you think it would help.
Employee
bill.bogan
Message 5 of 9 (2,246 Views)
08-03-2010 04:08 PM in reply to: SpitfireRcp
It's up to you. My preference is AVI - I like the results much better. Smoother, clearer output on my machines.
Many of the long time studio users have rendered avi using the techsmith codec (doesn't require additional baggage s/w like DivX wants you to take). You can get it free, here:
http://www.techsmith.com/codecs.asp
Once installed, restart Inventor, Inv Studio, and when you're ready, in the rendering dialog, when you name the output, select AVI as the type. When you click OK, it will ask for a codec - Techsmith should be in the list. (note: if it isn't, it may require a reboot of the machine to see it), it will prompt you for the codec - select Techsmith and proceed.
If you try AVI, let us know how it went.
Cheers,
Bill Bogan
Doug_DuPont
Message 6 of 9 (2,057 Views)
11-09-2010 06:23 AM in reply to: bill.bogan
Bill,
I am on Windows 7 64 Bit and have not been able to get this codec to Install. I have read that SmithTech does not have a 64 Bit Codec. Is that correct? I would like to make a compressed video that everyone can view without having to download something special.
Doug
Douglas DuPont
Inventor 2013
GeForce GTX 580
Windows 7 64 Bit
Employee
bill.bogan
Message 7 of 9 (2,043 Views)
11-09-2010 08:29 AM in reply to: Doug_DuPont
Hi Doug,
I went onto the Techsmith forum and looked for info about a 64 bit codec solution.
Here's what I found... "The 64-bit TSCC codec is installed with 7.1.0"
There latest upgrade to Camtasia Studio (7.1) apparently has a 64-bit codec. I am uncertain as to whether or not that codec is available for download from their site. One would think that it would be. Did you download the codec recently?
Another option would be to contact their support via email or phone and see if they can tell you whether or not the codec is/supports 64-bit OS.
To render compressed AVI or WMV, I would think, requires a codec of some sort and anyone viewing that video would need the codec. My codec exposure is fairly limited - techsmith, DivX, Xvid and all require you to have the codec on the machine for playback. I think that's the nature of the beast.
I haven't used MovieMaker from MS, but you could investigate whether or not it will accept images and turn that into video. Then, In Inventor, for render output, use the image sequence option and output to images. Use MovieMaker to assemble it to video and see what results. As I said, I've not tried this, so the result could be totally acceptable or unaccecptable. Maybe someone with MovieMaker experience can chime in.
Sorry I can't be of more assistance on this topic.
Bill Bogan
New Member
gmi_student09
Message 8 of 9 (1,320 Views)
12-10-2011 11:37 AM in reply to: SpitfireRcp
come visit my blog to watch mould animation . create by autodesk inventor 2011
give ur comment http://speechless009.blogspot.com/2011/12/two-plate-mould-with-slider-animation.html
jared
Message 9 of 9 (827 Views)
01-07-2013 06:02 AM in reply to: gmi_student09
i am having this same problem but i'm using Inventor Professional 2013.  any more recent advice?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
