5284 2012/04/12 13:38:02 Reason=Fatal error
5284 2012/04/12 13:38:02 ComputerName=OWNER-PC
5284 2012/04/12 13:38:02 OS=6.1.7601.Service Pack 1
5284 2012/04/12 13:38:02 File=AdlmFlxActTS.cpp,Line=611
5284 2012/04/12 13:38:02 AdlmActError=8 [An item is not found]
5284 2012/04/12 13:38:02 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
5284 2012/04/12 13:38:02 AdlmActError=18 [Argument to a function is bad]
2292 2012/04/12 13:38:03 Reason=Fatal error
2292 2012/04/12 13:38:03 ComputerName=OWNER-PC
2292 2012/04/12 13:38:03 OS=6.1.7601.Service Pack 1
2292 2012/04/12 13:38:03 File=AdlmIntSATSLicense.cpp,Line=416
2292 2012/04/12 13:38:03 VendorID=2 [ADLMACT]
2292 2012/04/12 13:38:03 VendorError=18 [Argument to a function is bad]
3496 2012/04/12 13:38:38 Reason=Fatal error
3496 2012/04/12 13:38:38 ComputerName=OWNER-PC
3496 2012/04/12 13:38:38 OS=6.1.7601.Service Pack 1
3496 2012/04/12 13:38:38 File=AdlmFlxActTS.cpp,Line=611
3496 2012/04/12 13:38:38 AdlmActError=8 [An item is not found]
3496 2012/04/12 13:38:38 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
3496 2012/04/12 13:38:38 AdlmActError=18 [Argument to a function is bad]
2736 2012/04/12 13:38:38 Reason=Fatal error
2736 2012/04/12 13:38:38 ComputerName=OWNER-PC
2736 2012/04/12 13:38:38 OS=6.1.7601.Service Pack 1
2736 2012/04/12 13:38:38 File=AdlmIntSATSLicense.cpp,Line=416
2736 2012/04/12 13:38:38 VendorID=2 [ADLMACT]
2736 2012/04/12 13:38:38 VendorError=18 [Argument to a function is bad]
5764 2012/04/12 13:41:36 Reason=Fatal error
5764 2012/04/12 13:41:36 ComputerName=OWNER-PC
5764 2012/04/12 13:41:36 OS=6.1.7601.Service Pack 1
5764 2012/04/12 13:41:36 File=AdlmFlxActTS.cpp,Line=611
5764 2012/04/12 13:41:36 AdlmActError=8 [An item is not found]
5764 2012/04/12 13:41:36 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
5764 2012/04/12 13:41:36 AdlmActError=18 [Argument to a function is bad]
4640 2012/04/12 13:41:36 Reason=Fatal error
4640 2012/04/12 13:41:36 ComputerName=OWNER-PC
4640 2012/04/12 13:41:36 OS=6.1.7601.Service Pack 1
4640 2012/04/12 13:41:36 File=AdlmIntSATSLicense.cpp,Line=416
4640 2012/04/12 13:41:36 VendorID=2 [ADLMACT]
4640 2012/04/12 13:41:36 VendorError=18 [Argument to a function is bad]
5524 2012/04/12 13:42:17 Reason=Fatal error
5524 2012/04/12 13:42:17 ComputerName=OWNER-PC
5524 2012/04/12 13:42:17 OS=6.1.7601.Service Pack 1
5524 2012/04/12 13:42:17 File=AdlmFlxActTS.cpp,Line=611
5524 2012/04/12 13:42:17 AdlmActError=8 [An item is not found]
5524 2012/04/12 13:42:17 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
5524 2012/04/12 13:42:17 AdlmActError=18 [Argument to a function is bad]
4752 2012/04/12 13:42:18 Reason=Fatal error
4752 2012/04/12 13:42:18 ComputerName=OWNER-PC
4752 2012/04/12 13:42:18 OS=6.1.7601.Service Pack 1
4752 2012/04/12 13:42:18 File=AdlmIntSATSLicense.cpp,Line=416
4752 2012/04/12 13:42:18 VendorID=2 [ADLMACT]
4752 2012/04/12 13:42:18 VendorError=18 [Argument to a function is bad]
4104 2012/04/12 22:00:09 Reason=Fatal error
4104 2012/04/12 22:00:09 ComputerName=OWNER-PC
4104 2012/04/12 22:00:09 OS=6.1.7601.Service Pack 1
4104 2012/04/12 22:00:09 File=AdlmFlxActTS.cpp,Line=611
4104 2012/04/12 22:00:09 AdlmActError=8 [An item is not found]
4104 2012/04/12 22:00:09 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
4104 2012/04/12 22:00:09 AdlmActError=18 [Argument to a function is bad]
2840 2012/04/12 22:00:10 Reason=Fatal error
2840 2012/04/12 22:00:10 ComputerName=OWNER-PC
2840 2012/04/12 22:00:10 OS=6.1.7601.Service Pack 1
2840 2012/04/12 22:00:10 File=AdlmIntSATSLicense.cpp,Line=416
2840 2012/04/12 22:00:10 VendorID=2 [ADLMACT]
2840 2012/04/12 22:00:10 VendorError=18 [Argument to a function is bad]
2840 2012/04/12 22:00:27 Reason=Fatal error
2840 2012/04/12 22:00:27 ComputerName=OWNER-PC
2840 2012/04/12 22:00:27 OS=6.1.7601.Service Pack 1
2840 2012/04/12 22:00:27 File=AdlmIntSATSLicense.cpp,Line=2164
2840 2012/04/12 22:00:27 AdlmIntError=17 [The license was not found]
420 2012/04/13 17:08:01 Reason=Fatal error
420 2012/04/13 17:08:01 ComputerName=OWNER-PC
420 2012/04/13 17:08:01 OS=6.1.7601.Service Pack 1
420 2012/04/13 17:08:01 File=AdlmFlxActTS.cpp,Line=611
420 2012/04/13 17:08:01 AdlmActError=8 [An item is not found]
420 2012/04/13 17:08:01 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
420 2012/04/13 17:08:01 AdlmActError=18 [Argument to a function is bad]
4072 2012/04/13 17:08:01 Reason=Fatal error
4072 2012/04/13 17:08:01 ComputerName=OWNER-PC
4072 2012/04/13 17:08:01 OS=6.1.7601.Service Pack 1
4072 2012/04/13 17:08:01 File=AdlmIntSATSLicense.cpp,Line=416
4072 2012/04/13 17:08:01 VendorID=2 [ADLMACT]
4072 2012/04/13 17:08:01 VendorError=18 [Argument to a function is bad]
2088 2012/04/13 17:24:41 Reason=Fatal error
2088 2012/04/13 17:24:41 ComputerName=OWNER-PC
2088 2012/04/13 17:24:41 OS=6.1.7601.Service Pack 1
2088 2012/04/13 17:24:41 File=AdlmFlxActTS.cpp,Line=611
2088 2012/04/13 17:24:41 AdlmActError=8 [An item is not found]
2088 2012/04/13 17:24:41 File=AdlmFlxActAppTrialAndConfigLicenseHandler.cpp,Line=397
2088 2012/04/13 17:24:41 AdlmActError=18 [Argument to a function is bad]
5332 2012/04/13 17:24:41 Reason=Fatal error
5332 2012/04/13 17:24:41 ComputerName=OWNER-PC
5332 2012/04/13 17:24:41 OS=6.1.7601.Service Pack 1
5332 2012/04/13 17:24:41 File=AdlmIntSATSLicense.cpp,Line=416
5332 2012/04/13 17:24:41 VendorID=2 [ADLMACT]
5332 2012/04/13 17:24:41 VendorError=18 [Argument to a function is bad]
Hello i have the same problem with my AUTOCAD 2012, can you explain me a little better what did you do to solve the problem withe the Inventor 2010 flexnet license error, i think it will work for me too! but i dont understand very well what u are trying to explain... i have a windows 7 64 bits, hope u can help me! im trying to fix it for to longg already!! THANKSS A LOT!
