Inventor Forum
Inventor 2009 User Tools installation
2 REPLIES 2
sebastien_tp
225 Views, 2 Replies
We are planning to deploy the usertools.msi file on all of our 'Inventors 2009' computers.
My problem concerns the msi file. I don't find any documentation about this file.
By default, if the msi file is on a UNC path, the installer tries to do the installation in this UNC path:
example : msiexec /i \\myserv\myfolder\usertools.msi /qb will try to install in \\myserv\myfolder\
Launched from the hard drive, files will be installed in the c:\UserTools\ folder.
While launched with the full UI, default path is where the msi file is stored.
I would like to specify my own path for the installation but what are the command line options to do so ?
I also wouls like specify that the installation concerns all users and not only me.
How could i do that ?
2 REPLIES 2
karthur1
in reply to: sebastien_tp
http://msdn.microsoft.com/en-us/library/aa367988.aspx
sebastien_tp
Yeah great but not at all what i need.
I already found the solution. here it is and the way i found it :
I did an installation using this kind of command :
msiexec /i usertools.msi /qn /l* c:\log.txt
I edited c:\log.txt and looked for path and userlevel variables.
After some tests these options are : targetdir and allusers
So my deployment command will be something like that :
msiexec /i \\myserv\myfolder\usertools.msi TARGETDIR="C:\Program Files\Autodesk\Inventor 2009\SDK" ALLUSERS=1 /qn
Here are the microsoft MSDN library about this :
http://msdn.microsoft.com/en-us/library/aa372064(VS.85).aspx
http://msdn.microsoft.com/en-us/library/aa367559(VS.85).aspx
