Inventor Forum
Internal Gears rotation opposite direction?
3 REPLIES 3
1582 Views, 3 Replies
Hi, I made internal gears with design accelerator.
It's calculation is OK. And drag it,the rotation is good, But the direction is opposite. The tooth's move opposite direction to each other.
How can I solve this?
I used Autodesk Inventor 2013, And  sp2, update DL22436649.zip
But, this appeard before And after sp2 patch.
It's bug?
3 REPLIES 3
Paul-Mason
Voltwave
I downloaded the files that you attached, unzipped them but they are either some corrupted files or some missing, see the screen shots below.
In my Normal Windows Explore setup I will see icon representation of the ipt, iam, etc files this is what I'm seeing for some of the files that you posted
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
in reply to: Paul-Mason
Merry Christmas Mason-Paul .
My question seem solved.
The Internal guar is move opposite direction in assemble mode, But It's move one direction each other in simulation mode.
Thank very much for your regards.
