Inventor Forum
Installation error message...
5 REPLIES 5
Jayman
109 Views, 5 Replies
I am trying to install IV7 and everytime the install starts to go, i get the following message... "internal error 2755. 1632 D:\inventor\inventor.msi" anyone got a fix for that? i just updated the this computer to w2k sp4 and all the trimmings that go with it so... i am out of ideas... i currently has 5.3 that does work so... ???
Cheers.
5 REPLIES 5
in reply to: Jayman
> Cheers.
Try searching the R6 NG with the keyword msi. There were a number of
instances of that type of error during R6 installations.
Are you installing from the CD or did you copy it to the HD and are
trying to install from the HD?
Hal Gwin
Mechanical Designer
Xenogen
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4345 drivers
Dell UltraSharp 19" LCD
Jayman
in reply to: Jayman
Hi Hal. I am installing from CD just like i have done on the 10 other machines i installed...?? it just dont make sense!! i will check the R6 group... Thanx.
in reply to: Jayman
> group... Thanx.
Did the other 10 machines have SP4 installed?
Hal Gwin
Mechanical Designer
Xenogen
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
Jayman
in reply to: Jayman
Ahhh... good question... only one of them did, and it is a brand new machine, this problem one is a couple years old now. Hmmmmm...
rllthomas
in reply to: Jayman
Make sure they all have IE6. Then I would suggest the instmsiw.exe file that installs the latest ms msi installer (say that 3 times real fast). You should be able to find that file from ms or perhaps in IV cd.
Rich Thomas
