Inventor General
New Member
Message 1 of 8 (2,587 Views)
Inserting a JPEG or BMP into a Drawing Sheet
2587 Views, 7 Replies
04-19-2010 10:57 PM
Hi guys
I am running inventor 2010 suite with service pack 2 and when I try to insert a JPEG or BMP into a Drawing Sheet (not a sketch on a part file), the image does not appear. I have done this on previous versions numerous times and it worked perfectly fine.
The message which appears on the screen says "TEMPEMBED.BMP" and it has a photoshop CS4 logo. When I do a print preview, nothing appears on the page. I have opened up a previous drawing sheet, which has a JPEG & BMP inserted and the image is shown, but when I try to insert another image on the same drawing sheet, the same thing happens.
I am running a pretty fast machine, with an intel i7 processor and a pretty hardcore graphic card. Any ideas?
*Dennis Jeffrey
Message 2 of 8 (2,584 Views)
Re: Inserting a JPEG or BMP into a Drawing Sheet
04-20-2010 12:16 AM in reply to: Dantron
Windows 7 right?
Works fine here in xp64. Sorry, cannot help if on Win7, as I do not have
a system running Win7 yet.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Subscribe to the free "The Creative Inventor Magazine now available at:
http://teknigroup.com/CI-Subscribe-Login.asp
*Sam M
Message 3 of 8 (2,584 Views)
04-20-2010 12:43 AM in reply to: Dantron
what is your default program to open image files?
If you're getting a Photoshop logo is that it? Remember you need
Microsoft's Paint to be the default program for images to work (know this is
the case with decals, so possibly true here too).
wrote in message news:6376096@discussion.autodesk.com...
Hi guys
New Member
Message 4 of 8 (2,584 Views)
04-20-2010 04:16 PM in reply to: Dantron
Hi Sam
I have changed my default image viewer to photopaint and then windows image viewer and the same problem still persists. Photoshop is not the default image viewer.
Distinguished Contributor
Message 5 of 8 (2,585 Views)
04-28-2010 12:21 PM in reply to: Dantron
I am having the same kind of issue except I can not even get to the point where I am inserting the raster image. The "insert file" option on the sheet screen is grayed out. I am using 64-bit Vista (yes, I know but I was not asked).
Any suggestions would be greatly appreciated.
Active Contributor
Message 6 of 8 (2,585 Views)
04-29-2010 10:06 AM in reply to: Dantron
I had this problem. It was cured by rebuilding the windows user profile. I would suggest to contact autodesk support
--dave
Message 7 of 8 (2,580 Views)
06-09-2010 08:07 AM in reply to: Dantron
Has anyone found a solution for this yet?
Running 2010 sp3 on Win7 64bit
Mauricio
Valued Contributor
thedelee
Message 8 of 8 (1,474 Views)
11-07-2011 08:08 AM in reply to: Dantron
MANAGE TAB , INSERT OBJECT, CREATE FROM FILE , BROWSE TO IT, BOOM.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
