I too, am having this same issue. I am using the frame generator to create W-Shape I-beams in an assembly. The help file states that it can use work points and that is the easiest way for me to define the orientation and location of these beams. Was there ever a solution for this problem or did I miss it somewhere in the replies? I see the option that tells you to select and beginning and end point but even that doesn't work. Thank you!
