I want to add our company logos to a few drawings. I added a small thumbnail to the title block a while ago. In the sketch tab, Insert, Image, I can drop in bmp's. However, when I'm trying to ad it directly to the sheet nest to a text box or part view, I don't know how to. If I create a new sketch, the Image icon in the sketch tab is grayed out.
How do I insert an image in my idw?
Solved by Curtis_Waguespack. Go to Solution.
Hi eveylynne,
You can create a Sketched Symbol, and place the image in the symbol, and then place it as needed onto the drawing sheet.
I hope this helps.
Curtis
Hi
To insert image on drawing, you need, insert from file, and if you want , you can link the image with the drawing in other words if the image will be modified it will be affected to the drawing. For me, i prefer to don't link the inserted file
GO TO
Manage
Insert Object
create from file
Copy and paste the file location example ;C:\Users\CADAPP\Pictures
BROWSE
pic jpeg OPEN
Enjoy
