Good morning,
I want to insert arrows into an idw. I usually use 'Leader Text' then leave the text blank.
The only problem with this method is it leaves a small horizontal or vertical line at the 'text' end of the arrow. Is there a way to get rid of this or is there an alternative way of inserting an arrow?
Solved by -niels-. Go to Solution.
Also, I don't want to just create a sketch symbol as I need to be able to easily resize/reposition
Alternative way:
Make a new balloon style, set the shape to "none - all entries" and make it display an empty property.
(easiest is to use a custom property that doesn't exist in your models)
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thanks for this tip on making a new balloon style. The only problem with this method is that the balloon needs to be attached to an object (or at least I believe it does). Is there a way to have a balloon (or leader without extension line) that is able to float freely on the drawing sheet?
Niels van der Veer
The Netherlands
Thanks! I actually discovered this by accident just before your post. I dragged the balloon off an object & moved it to the desired location. The arrow changed to a large dot, so I just right-clicked on the balloon & hit "Edit Arrowhead" to manually change it to a filled arrow.
I also right-clicked on the balloon & used the "Attach Text to Leader" option. The text aligns nicely with the balloon line regardless of where you move it.
Another way to do this is to look up the alt codes.
I used Alt+26 for a right arrow. It did not work directly in the inventor text box so I did it in outlook first then copy and pasted the text into the Inventor text box. Now you can move it anywhere change size and any other feature you can do to text.
