Inventor General
trus
Message 1 of 5 (637 Views)
Input 3D Cartesian coordinates: Batch Input (x, y, z)
637 Views, 4 Replies
02-04-2013 08:51 AM
My need is to create up to 50 points from the same origin in a three dimensional Cartesian coordinate system but I’d also like to have a labels for each point that show up in the feature tree.
Are there Inventor 2013 plugin (i.e., add-on, 3rd party, AP) to convert a list 3D Cartesian coordinate  system locations (i.e., points) to Inventor to work points(x, y, z)?
As a new Inventor user, I found that I cannot create 3D points in the assembly.  Is this correct?
I did find that an Inventor part may be used to create a 3D sketch that creates points in 3D space.  In the past few days, I  found  two ways to create 3D points within a iPRT; the batch way uses an Excel file but it then does not allow me to name the points in the feature tree.  The second way is to create them one at a time but that take way too much time.
Thank you,
Tony
JDMather
Message 2 of 5 (630 Views)
Re: Input 3D Cartesian coordinates: Batch Input (x, y, z)
02-04-2013 09:28 AM in reply to: trus
....additional information - it sounds to me like you are referring to WorkPoints rather than sketch points.
Workpoints can be created in assembly or part and can be named in browser - but the challenge will be figuring out how to create (a lot of) them.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
trus
Message 3 of 5 (626 Views)
02-04-2013 09:33 AM in reply to: JDMather
What is difference between a sketch point and a work point?
JDMather
Message 4 of 5 (622 Views)
02-04-2013 09:37 AM in reply to: trus
Can you attach here a short list of coordinates?
The best way to demonstrate might be with an Inventor file.
What version of Inventor did you say you are using?
trus
Message 5 of 5 (611 Views)
02-04-2013 10:16 AM in reply to: JDMather
I'm a brand new user to the AutoDesk software and I'm using Inventor 2013. Per your request, please find attached a file formatted using Excel 2010. So what is the difference between a sketched point and a work point? Thank you, Tony Number Point Name x y z Type of Dimension 1 A 0.0000 0.0000 0.0000 Basic 2 C 0.0631 -2.8411 0.0000 Basic 3 D 0.9211 -7.3442 0.0000 Basic 4 E 2.4886 -11.6518 0.0000 Basic 5 G 3.7309 -13.8696 0.0000 Basic 6 J 5.9315 -17.6534 0.0000 Basic 7 K 11.9401 -23.3128 0.0000 Basic 8 L 19.3087 -27.0324 0.0000 Basic 9 N 24.1108 -27.8834 0.0000 Basic 10 R 32.9192 -29.0256 0.0000 Basic 11 S 47.7037 -22.2464 0.0000 Basic 12 T 56.6744 -8.6793 0.0000 Basic 13 V 56.8984 0.5600 0.0000 +/- 0.06 14 W 3.7309 -13.8696 2.2570 +/- 0.06 15 AA 11.6037 -22.7051 0.0000 Reference 16 AB 11.6037 -22.7051 2.2568 +/- 0.06
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
