I'd like to be able to vastly increase the size of the triad in the 3D Sketch environment - when sketching the triad is tiny and does not increase in size when zooming, this makes snapping to its planes extremely difficult. Please can someone tell me how to at least double it's size, thanks.
Solved by JDMather. Go to Solution.
I haven't checked this,
but what happens if you go to Tools>Application Options>General tab and increase the Annotation Scale height?
The CADWhisperer YouTube Channel
Try setting it to 5.
Can you see it now?
Thank you, yes this increases the triad size but also everything else on the sketch, it would be better if Inventor has a command similar to CAD where the UCS can be sized on its own
Do you really need the ucs glyph?
