Inventor Forum
Increasing Edge display weights?
4 REPLIES 4
1500 Views, 4 Replies
Is there a way to increase the edge weights/color of a part/assembly?
To see what I mean I attached a screenshot of a simple cylinder with the view set to shading with edges. Yeah the edges are there, but I'd really like them to stand out more.
Tags (2)
4 REPLIES 4
karthur1
What color scheme are you running?  you could try changing to a different one and see if that help you, but I think thats about it.
Look in Tools>Application options, Display tab. Click on the Settings button here.  In the Display Appearance window, you can change the edges color under "Model Edges".
in reply to: karthur1
hmm, ok. I changed the color to black and it kind of helped, but it's still not as good as I would like it to be.
karthur1
In the model edges, select one color, then change the color to something other than black.... try yellow.
Does that help?  No way that I know to make the edges "thicker".
I tried yellow, red, and a few others and to me black stands out the most. Too bad I can't increase the line display thickness 😞 I like the thickness it displays sketches with.
