When I have part with surface and make drawing Inventor shows surface - tag Include all surface is default.
I want exclude Include all surface tag by default and tag when I need.
In Inventor 2013 this function doesn't work
When a file contains surfaces, but also at least one solid body then they are automaticly exluded from the drawing views.
I try with part and assembly consist solid body and surface tag is included from the drawing views.
yes, i have a very similar problem.
any surface in a model is always visible by default, sometimes I have to make the surfaces invisible in the model before I can even use the option of un-including all surfaces.
this has only started since going to IV2013
I am seeing the same problem too, only in 2013. even when I open an old drawing and change the view scale the surfaces come in, then I have to check the "include all surfaces" from the model tree and then immediately uncheck the "include all surfaces" to turn them off.
is there a default setting somewhere that I am missing?
Gene
I have the same problem too, and only since moving to 2013.
I think it is something to do with the fact Inventor now implements View Reps for Parts, albeit in a very messy and barely workable fashion.
I do have some assemblies that behave when a drawing is created of them and I've just been experimenting with them and trying to work out a pattern. I'm not sure if this is the final answer:-
I think it is the Master View Rep of the assembly that misbehaves. No matter what you have displayed when viewing the Master in assembly view, when you create a drawing of it it will display all surfaces. Create a new View Rep of the assembly and get this set up correctly with no surfaces or only certain surfaces displayed. A drawing of this new View Rep should (hopefully!) come in correctly. Note that you can update current drawings by changing which View Rep is displayed in the Edit View dialog. You might also need to force this to update sometimes- right-click on the drawing View in the browser and select Apply Design View.
it seems to me that the ipt master view rep and the idw view rep does not maintain accosiative beyond initial view placement.
Now I have to select "include all surfaces" which turns them all on, and immediately select include all surfaces again to turn them off, and I have to do this for every view that is on the drawing regardless of accosiativity to the Base view, and this is really causing a lot of work.
yes creating a new view rep does hide the surfaces if you check the drawing view rep associative link, but I have over 10 years of drawings that were created using the master view representation,
a workflow that I have promoted here at wipaire is to make a copy object surface of a part solid before revising any geometry. then rename the surface as Rev A, Rev B...ect, this provides revision history right in the model. it also helps to make the drafter aware of any geometry that might have changed inadvertently.
With some help from the customization group (I think it was an Autodesk employee), I managed to put together the following macro which iterates through all the views on the active sheet and turns of all surface visibility in each view. Not sure it will work in all cases, but I made sure it works when there are parts suppressed in the active LOD rep for each view. It definately makes my job a bit easier:
Public Sub SetSurfaceVisibilityOff() ' Set a reference to the currently active drawing document. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument ' Get the active sheet. Dim oSheet As Sheet Set oSheet = oDrawDoc.ActiveSheet ' Get the selected view. Dim oDrawView As Inventor.DrawingView Dim oNumViews As Integer 'Set oDrawView = oDrawDoc.ActiveSheet.DrawingViews.Item(1) Dim oAsmDoc As AssemblyDocument Dim oCompDef As AssemblyComponentDefinition Dim oLeafOccs As ComponentOccurrencesEnumerator Dim oOcc As ComponentOccurrence Dim oWorkSurface As WorkSurface Dim oSurface As SurfaceBody Dim oFeature As PartFeature Dim oFeatureProxy As Object oNumViews = oDrawDoc.ActiveSheet.DrawingViews.Count Dim oProgBar As ProgressBar Set oProgBar = ThisApplication.CreateProgressBar(False, oNumViews, "View Processing Progress") oProgBar.Message = "Processing " & oNumViews & " Views" For Each oDrawView In oDrawDoc.ActiveSheet.DrawingViews ' Get the assembly shown in the view. Debug.Print "Processing View: " & oDrawView.Name oProgBar.Message = "Processing View: " & oDrawView.Name oProgBar.UpdateProgress Set oAsmDoc = oDrawView.ReferencedDocumentDescriptor.ReferencedDocument ' Get the component defenition Set oCompDef = oAsmDoc.ComponentDefinition ' Get all of the leaf occurrences of the assembly. Set oLeafOccs = oCompDef.Occurrences.AllLeafOccurrences For Each oOcc In oLeafOccs ' We are only interested in PartComponentDefinition's ' because only they can have WorkSurfaces ' In theory not even an empty assembly could be considered a ' leaf occurrence, but we check anyway If oOcc.Suppressed = False Then If TypeOf oOcc.Definition Is PartComponentDefinition Then For Each oWorkSurface In oOcc.Definition.WorkSurfaces For Each oSurface In oWorkSurface.SurfaceBodies Set oFeature = oSurface.CreatedByFeature Call oOcc.CreateGeometryProxy(oFeature, oFeatureProxy) Call oDrawView.SetVisibility(oFeatureProxy, False) Next Next End If End If Next Next oProgBar.Close End Sub
Hi there,
I'm not very familiar with VB, but managed to make the macro with the script. It does work untill a view of a IPN is reached then it stops with a error in the following line:
What can I do to add or fix?
I posted about this a while ago, the only solution was to go into every part and delete the construction surfaces with delete face - lump. But now I have another problem.
I dervied in a solid to many parts to use as a boolean cut, the model is correct but the cutting part shows in the drawing and there is no way to get rid of it.
Guess I have to go into autocad as usual to clean up inventors mess.
