Inventor Forum
Importing .stp files into Inventor
8 REPLIES 8
Message 1 of 9
7973 Views, 8 Replies
I have a .stp file that I can open in Inventor but I need to be able to project geometry on to it.  Is this possible?  Any help would be great.
8 REPLIES 8
Message 2 of 9
MariaManuela
Hi....yes it is possible.
Asidek Consultant Specialist
www.asidek.es
Message 3 of 9
Allen.Bai
Sure. You can just project geometry you want on to the imported STEP file.
Is there any problem you encountered?
Allen Bai
Senior User Experience Designer
Design, Lifecycle & Simulation
Message 4 of 9
JDMather
How did you import the STEP?
as solid?
as composite surface?
More information is needed.
Can you attach the STEP and resulting *.ipt here?
You can edit any surface or solid geometry in Inventor.
Message 5 of 9
jrittenhouse
Can anyone tell me why a .stp file import will only for solids but will not if you try to import only the surfaces?
Message 6 of 9
JDMather
in reply to: jrittenhouse
You didn't answer any of the questions above.
Attach your STEP file here.
Asking the same question multiple times will not likely result in different answers.
You can also Unstitch a solid into surfaces, but I suspect you will need to provide more information.
Message 7 of 9
jrittenhouse
in reply to: JDMather
i am aware of the procedure.  Please answer the question if you have the answer. I already know how to do this. I just want to know why some files can use just surface while others use solid.
Message 8 of 9
Hi jrittenhouse,
I think it is depended on the original STEP file contents, you know that STEP format is a neutral format and can generated by many CAD software (i.e. Inventor, SolidWorks, NX, ProE, CATIA......), so if the original model designed in CAD software has only solid geometry then the exported STEP file will also has only solid information and also only solid can be imported into Inventor, vice-versa for surface geometry.
Correct me if I am mis-understanding your question.
Kevin Li
Quality Assurance Team
Autodesk, Inc.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 9 of 9
Thank you very much for that insight.
