Hi, I import a dwg file with a surface model into inventor and then I when I go to stich the surfaces, y select the surfaces but there is not the option to apply to make a solid.
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
Are these individual surface or one Composite Surface.
Can you attach the file here?
Hi, thank you for answering, the surfaces where stiched in inventor fusion but they are not a solid there is one surface that I didn t stiched. I was trying to solved the stich in inventor fusion and y proffesional but in fusion the model have some error that fusion can not read the file. I was unable to atach the file here because it excedes the limit capacity, I could try to send you to your in box
Thanks, regards
Open the Inventor file.
Find the red End of Part marker in the feature browser.
Drag the red EOP to the top of the browser hidding all features.
Save the file with the EOP in this rolled up state.
In Windows Explorer right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here (assuming it is not smaller than the 1.5 limit.).
